    Change Paper Size
    layout
    3 Posts 3 Posters 2.0k Views 3 Watching
    • C
      clintwalk
      Is there a way to change the size of a layout drawing after it has been created? I understand you can go to Document Setup and change the paper size, but all the elements stay the same. I'd like to have all the elements scale down so I don't have to go resize every aspect, including all font sizes.
      As an example: I've created a layout document as an Arch D size. Now I'd like to print it as Tabloid (11x17). Any easy way to automatically scale this down (or up for that matter)?
      • GaieusG
        No matter what you have in the document setup, you can define a different paper under the page setup which will eventually define what size of paper you print it (and it will be scaled accordingly).
        • J
          jhauswirth
          You could try exporting to PDF and printing from Adobe Reader with scaling options.
