    Exporting jpeg plan views with dimensions
    9 Posts 2 Posters 676 Views 2 Watching
    • K Offline
      kurma
      I need to export a 2d plan view with dimensions but they are too big in relation to the plan. Is there some way of reducing the text size? To export the plan parts and patch them together is laborious and surely the worst way of doing it
        Hi Kurma (and welcome back πŸ˜‰ )
        Open Window > Model info and under the dimensions tab, select Font. There set it to height (instead of pt) and experiment with the size until you like it.
        When set, press the "select all..." button then the "update..." button.
        • K Offline
          kurma
          Thanks - you are on the ball πŸ˜„ Sketchup looks deceptively simple - there is an awful lot under the hood.
            When selecting the jpg export format, there is an "Options" button at the bottom right. Only your system memory is the limit what you can export (theoretically up to 9999 x 9999 pixels)
            • K Offline
              kurma
              Is there a way to set the resolution of the exported jpeg file? The dimensions sizes are now okay but the poor resolution makes them unreadable.
              Never mind - I got the answer - the export image dialog box contains an option for changing the resolution.
              • K Offline
                kurma
                You were too quick - but not quick enough πŸ˜„
                  That's what my wife keeps saying... πŸ˜’
                  • K Offline
                    kurma
                    Aha - always one step ahead of you. I could live with that as long as it wasn't rubbed in my nose.
                    • K Offline
                      kurma
