    Mayan Sacrificial Pyramid [WIP]
    15 Posts 5 Posters 2.7k Views 5 Watching
      lucifer1101
      Mayan Temple Project
      By Lucifer1101 - Jason S
      The latest project I have been working on was spurred by recent news of the largest pyramid in the world possibly being mayan. This is not a replica of that pyramid just something I wanted to make on my own. The pyramid is for sacrificial and living querters with a network of tunnels and chambers lying in the center of the pyramid.
      I finished the main modelling of the pyramid a few days ago, so I will post up those results now.
      A birds eye view of the pyramid.
      A view looking from one of the stair wells to the temple at the summit.
      A stairwell in one of the inner chambers of the pyramid.
      A view of the main staircase leading to the temple at the summit
      An interior view of the chambers.
      A view of one of the two secondary balconies with a scale refence.
      A section view showing more of the interior of the chambers.
      Please give out some c&c.
      I am obviously not the best modeller but I do try my best to work at this, but I don't waste time on failed projects either.
      This is also not finished, I plan on adding more detail and maybe a textured version for rendering...
      Some of my 3d
      • numbthumbN Offline
        numbthumb
        Since you´ve put in the effort to make the interior, are you planning on making some interactive walkthrough as well?
        Looking forward to seeing it textured and rendered!
        Comfortably numb...
          lucifer1101
          I may make one, I haven't done one before.
          Maybe somebody can point me in the right direction..
          Some of my 3d
            numbthumb
            http://www.walkabout3d.com/ ?
            Comfortably numb...
              lucifer1101
              I am a little short on the money part, so I wont be able to on that. I may try to make on in another 3d program...\
              Anyway here is an update to hopefully get people interested.
              I added a greeble like effect.
              Some of my 3d
              • Bryan KB Offline
                SU has it's own built-in walk-through. I think there are tuts on Google forums or here.
                That model is looking good. I can't wait to see it finished as well.
                  lucifer1101
                  I just tried out the sketchup scenes and god are they awful, if I am trying to traverse through tight little tunnels there is no way to really make sure you dont go through the walls, I think if I do a walkthrough I will make it in something with path editing.. (No offense)
                  Some of my 3d
                  • andybotA Offline
                    andybot
                    There is a way to path animate in SU with Fredo6 polyline divider tool and flightpath rubies. The tutorial for it is here at the bz-animation plugin: http://forums.sketchucation.com/viewtopic.php?f=323&t=20173&p=167997&hilit=flightpath#p167997
                    A caution - if you have a long path, you will get a huge number of scenes. I usually split my model up into different sections of the path once I am ready to render, this way the amount of scenes is under control. (and also I can take advantage of multiple processor cores...)
                    -Andy
                    Oh yeah, and crazy model! It'll look pretty cool with textures and maybe some Mayans to boot...
                      lucifer1101
                      Another Update!
                      Looking up at the temple from a balcony.
                      Some of my 3d
                      • pbacotP Offline
                        intriguing model. Just the sort of thing I'd like to model. Looking good. You might try some corbel arches and vaults like the Mayans used. Would look cool.
                          lucifer1101
                          I missed that one, thankyou for pointing it out, although it is a little late and would take some effort to actually install some into the model..
                          EDIT: I just realized that the Mayans designed each pyramid for very specific purposes bot on most you can see a snake formed by the shadows on the vernal equinox with the snakes head being a sculpture...
                          http://s4.hubimg.com/u/2303479_f520.jpg
                          Just amazing how much goes into the megalithic marvels..
                          This website seems to be quite informative..
                          Some of my 3d
                            lucifer1101
                            I have almost finished putting in block details, I wont be putting the corbel arches into this one, but I plan on doing some more and I will put them into those ones..
                            --UPDATE--
                            Looking up the main stairs to the temple.
                            Some of my 3d
                              lucifer1101
                              The Block detailing is complete, I will try a couple of renders and then go into texturing it..
                              Some of my 3d
                                lucifer1101
                                A few AO renders to wet the lips with. On to texturing, and then more renders and more models to make a great scene for this..
                                What do you think?
                                Some of my 3d
                                  lucifer1101
                                  I am definately not that good at rendering or getting the textures right, but I gave it a try in kerkythea anyway. I want to try a few different programs that I can get for free or already have so bare with me while I try to get this done in scorching heat.
                                  My computer overheated yesturday so I don't know if it will today, otherwise the first renders would be up already.
                                  Anyway pass on the comments please..
                                  EDIT: These are PhotonMap High + AA 0.3 Renders.
                                  Some of my 3d
