    Help with acess to registry from observer
    10 Posts 3 Posters 709 Views 3 Watching
    • honoluludesktopH
      honoluludesktop
      Sketchup.read_default fails to access the registry with the following code, and returns nil although I have verified that there is a value in v_name. Anyone care to discuss?
      class AtelierModelObserver<Sketchup;;ModelObserver
        def onSaveModel(model)
          result=Sketchup.read_default("label","v_name","default")
          if result==nil
            #undocumented PC only exit command.
            Sketchup.send_action 57602
      • thomthomT
        result=Sketchup.read_default("label","v_name","default") This gives you nil?
        You added the string "default" to the optional default value - which means it should return "default" if the value is not set.
        How are you verifying that you have a value for v_name? What value is set in the registry? What ruby value type do you use to set the value?
        • honoluludesktopH
          honoluludesktop
          In the first instance of Sketchup, the plugin writes to the register, and waits at a UI.messagebox midway. At this time, the second instance of sketchup, saves its model, calls the observer, to checks the register, but nil is returned. I use regedit to check the values in the register as I step through the program. In this case nil works for me, but I would like to know whats happening. Maybe one instance locks access to the register from the other? I am in the process of posting the plugin.
          • honoluludesktopH
            honoluludesktop
            Plugin posted here.
            • thomthomT
              So what is the value you see in the register?
              Does the register actually change as you use write_default ? Or is it delayed until SketchUp closes?
              • honoluludesktopH
                honoluludesktop
                Regedit shows the write_default changes the register, but when read_default is placed in the observer, it returns nil.
                • Dan RathbunD
                  Dan Rathbun
                  I believe I posted the 3rd argument bug for Sketchup.read_default() in the API topic. I have to check the beta bug list on this.
                  EDIT: YES.. I did report this bug ...
                  @dan rathbun said:
                  Any attempt to read a Registry DWORD value returns nil.
                  The 3rd argument is not returned on failure.
                  The bug was already listed in Google's buglist as number 2435419
                  I'm not here much anymore.
                  • Dan RathbunD
                    Dan Rathbun
                    I bumped the bug report.
                    • honoluludesktopH
                      honoluludesktop
                      Good to know. In my case, I assumed that returning nil in that situation was a sign that the second instance of Sketchup was running. Guess I'll add or v_name==the_vari for when it gets fixed:-)
                      • Dan RathbunD
                        Dan Rathbun
                        There'a a major drawback to using the API "default" methods.
                        That is they did not give us a "remove_default" method.
                        This means the Win Registry or Mac plist can become cluttered with old 'orphaned' settings for plugins that are no longer used.
                        Many authors (TIG is one I think,) that instead write out their own settings file in the plugin subfolder. I think he has posted code snippets in other topic threads.
                        Basically you write out a string report of your settings Hash to a text file, using the inspect method.
                        To reload it, you read the file into a String object, and then eval() the string inside the context of your module, assigning it to a var, which should become type Hash after evaluation.
