Help with acess to registry from observer
Sketchup.read_defaultfails to access the registry with the following code, and returns nil although I have verified that there is a value inv_name. Anyone care to discuss?class AtelierModelObserver<Sketchup;;ModelObserver def onSaveModel(model) result=Sketchup.read_default("label","v_name","default") if result==nil #undocumented PC only exit command. Sketchup.send_action 57602 end end end -
result=Sketchup.read_default("label","v_name","default")This gives younil?
You added the string"default"to the optional default value - which means it should return"default"if the value is not set.How are you verifying that you have a value for
v_name? What value is set in the registry? What ruby value type do you use to set the value? -
In the first instance of Sketchup, the plugin writes to the register, and waits at a UI.messagebox midway. At this time, the second instance of sketchup, saves its model, calls the observer, to checks the register, but nil is returned. I use regedit to check the values in the register as I step through the program. In this case nil works for me, but I would like to know whats happening. Maybe one instance locks access to the register from the other? I am in the process of posting the plugin.
Plugin posted here.
So what is the value you see in the register?
Does the register actually change as you usewrite_default? Or is it delayed until SketchUp closes? -
Regedit shows the
write_defaultchanges the register, but whenread_defaultis placed in the observer, it returns nil. -
I believe I posted the 3rd argument bug for Sketchup.read_default() in the API topic. I have to check the beta bug list on this.
EDIT: YES.. I did report this bug ...
@dan rathbun said:
Any attempt to read a Registry DWORD value returns nil.
The 3rd argument is not returned on failure.The bug was already listed in Google's buglist as number 2435419
I bumped the bug report.
Good to know. In my case, I assumed that returning nil in that situation was a sign that the second instance of Sketchup was running. Guess I'll add
or v_name==the_varifor when it gets fixed:-) -
There'a a major drawback to using the API "default" methods.
That is they did not give us a "remove_default" method.
This means the Win Registry or Mac plist can become cluttered with old 'orphaned' settings for plugins that are no longer used.Many authors (TIG is one I think,) that instead write out their own settings file in the plugin subfolder. I think he has posted code snippets in other topic threads.
Basically you write out a string report of your settings Hash to a text file, using the inspect method.
To reload it, you read the file into a String object, and then eval() the string inside the context of your module, assigning it to a var, which should become type Hash after evaluation.
