    Merging Terrain Files?
    2 Posts 2 Posters 459 Views 2 Watching
    • F Offline
      fjb80
      Hello All,
      I've got detailed topo lines (0.5m) for a site, but want to add some more context by merging the detailed model with terrain downloaded from Google Earth. Does anyone know if this can be done? If so, how?
        You could use the stamp tool from the sandbox to add your topo to the downloaded area.
        First unlock the downloaded terrain then either explode it or put your topo inside the terrain group. Use the stamp tool. Now you have little control over precise vertical placement but once you stamped the topo, it will create a surface with hard edges around so you can select it and use the move tool to adjust the final placement. Finally soften all the edges.
