    [Plugin] ImageTrimmer
    364 Posts 58 Posters 278.0k Views 58 Watching
      Has it then made the other files in the 'Trimmed' folder ?
      If so we know it's both runnable and working...
      Is there a .dat file?
      This tells Ruby where to draw the edges that are the image's 'perimeter' ?
      Can you PM a zip of the Trimmed folder including any .dat file to me ?
      So why isn't it then reading the .dat file? πŸ˜•
      • eLaCiDE Offline
        eLaCiD
        Well, we have three situations..
        1.)
        When I start ImageTrimer from SU then
        in files from.ini and to.iniappears correct path
        And nothing more.
        2.)
        When I start manualy by click EdgeDetector.jar
        with the condition - there is corect path in files from.ini and to.ini
        and condtition - there is image.png inTrimmedImagesfolder
        In folder TrimmedImages next to image.pngappears image[Edges].datand image[Edges].png
        3.)
        When I start EdgeDetector.jarinside RC nothing happens.
        Files image[Edges].datand image[Edges].png doesn't appear in b] TrimmedImages [/b] folder
        Zip of TrimmedImage folder is sent over PM
          A .jar file won't execute through the RC unless you use UI.openURL("file:///"+full_path_to_jar), which we know works... I think - please retry and confirm this if there's any doubt...
          The edges dat file that is necessary is made in the set you PM'd, and it is fine - here's a zoomed out view of the 'text' - you can clearly see the 0/1 pattern matching the image outline !
          So why isn't it working through the main ruby code ?
          The .jar isn't 'executing' in the code...
          So there must be something wrong with either your permissions - are you an admin ?
          OR perhaps the Java settings are not right for some reason???
          Do you AND ALL others have FULL access to the TrimmedImages folder ?
          Perhaps you do but others like Java/Sketchup don't ???
          Is there FULL rights for ALL to the SKMtools folder/files and subfolders ???
          It's as if something is stopping the one step needed with the jar file 'opening' and making the dat file...
          • eLaCiDE Offline
            eLaCiD
            On this computer is only one user acount - my, with description computer administrator.
            Full Java sattings I posted here before.
            All folder with subfolder and files in that folders have full rights for ALL
            The catch is somewhere here :
            EdgeDetector.jar works if is started manualy by click
            EdgeDetector.jar doesn't work from RC
            When it would be?
              If you right-click a jar file and use 'open with...' what does it say ?
              Try execute with Java ?
              The one difference in the Java Advanced settings between me/you - mentioned earlier - can you try the alternative 'off'...
              • eLaCiDE Offline
                eLaCiD
                I got this
                • eLaCiDE Offline
                  eLaCiD
                  Conclusion - Chapter 2
                  After many attempts, I came up with something that could lead to a solution.
                  As I am not friendly with Ruby I tried the following
                  First. I saw that when I run ImageTrimmer from SU in TrimmedImages folder only get copy of bacic image - someimage.png
                  Then I saw if I directly run EdgeDetector.jar in TrimmedImages folder I get two files someimage[Edges].dat and someimage[Edges].png
                  Next I saw when I run ImageTrimmer from SU at start all existing files in TrimmedImages folder are deleted.
                  Well then I do next :
                  I start directly EdgeDetector.jar and I get necessery files someimage[Edges].dat and someimage[Edges].png and I copy them out from TrimmedImagesfolder.
                  Then I start ImageTrimmer from SU (of course ImageTrimer at start delete this two files from TrimmedImages folder but I have copy of them)
                  When ImageTrimmer are working I copy back someimage[Edges].dat and someimage[Edges].png in TrimmedImages folder
                  And on this way plugin works. πŸ‘
                  As I said before Hope dies last and surrender is not an option. πŸ˜„
                  TIG, now is your turn 😍
                  My grandad who died many years ago and never seen computor know to say something that might be in translation :
                  You dont have to know everything, but you need to know how to handle πŸ˜„
                    Another thought...
                    Please check your permissions for the SKMtools folder/contents are FULL for EVERYONE...
                    If you right-click a jar file and use 'Open with...' and choose 'Set default program...'
                    Try to re-force it to execute with Java, by re-choosing the Java .exe and checking the box 'Always open with this...'
                    Also recheck each of the Java Control Panel settings match these, which work for me:
                    • eLaCiDE Offline
                      eLaCiD
                      @tig said:
                      Another thought...
                      I did like you said.
                      SKMtools folder/contents are FULL for EVERYONE (it was before)
                      Java 'Open with' - re-choosing the Java .exe - 'Always open with this...'
                      It was done.
                      Java settings is like you post here except I can't mark Mozilla family box then only IE box.
                      If I mark MF box after click on OK and re-open it shosw again only IE box marked.
                      But unfortunately it did not bring anything new.
                        I can't see how to do anything more πŸ˜•
                        At least you have a work around...
                        • eLaCiDE Offline
                          eLaCiD
                          Maybe you can't maybe you can πŸ˜„
                          I am not friendly with Ruby but as I can see with this type of error "No such file or directory" I am not alone.
                          It seems on some PC configuration for some reason proces is not able to save image[Edges].dat and image[Edges].png in TrimmedImages folder.
                          There is possibility of syntax in code perhaps?
                          In this moment I can't see other reason.
                          Anyway thank you for your time πŸ˜„
                            camaxide
                            I have used many images successfully but this one seem to crash as soon as it jumps to the part where it should trace the outlines, however - it makes an image in the folder before it crashes. it crashes the entire sketchup.
                            http://i42.tinypic.com/jtay9u.png
                            http://i39.tinypic.com/4q4yth.png
                            Any ideas?
                            On a sidenote - many of the images I had would not trim on my work computer using the newest sketchup - but my home computer with the last google version of sketchup seem to run most fine - except this one.
                              It might just be too complex an outline...
                              It is a large file, have you tried reducing its resolution ?
                              You can make the image say 1600mm high as you pace it...
                              I tried it at 800px high and it ImageTrimmed fine...
                              I can't see much difference in the image/texture quality...
                              If you don't want to reduce the resolution try splitting the image into two separate girls.
                              You can always recombine the cutouts' geometry into one component later...
                                camaxide
                                thanks a lot, very useful reply - I only tried to open, and resave the file making sure it had no sub-transparent pixels.. but I didnt try changing res. Thanks a lot πŸ˜„
                                • deaneauD Offline
                                  deaneau
                                  Hi TIG
                                  i have the problem with image trimmer
                                  the ruby console show this
                                  the same error messages in 8pro
                                  whats wrong?
                                  thanks dean
                                  Error: #<Errno::ENOENT: No such file or directory - C:\Users\d\Documents\TrimmedImages\Grenzer_hockt-front_mit_Telefon_klein___[Edges].dat>
                                  C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/SKMtools/ImageTrimmer.rb:238:in readlines' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/SKMtools/ImageTrimmer.rb:238:in make_edges'
                                  C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/SKMtools/ImageTrimmer.rb:187:in process_image' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/SKMtools/ImageTrimmer.rb:164:in initialize'
                                  C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/SKMtools/ImageTrimmer.rb:769:in new' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/SKMtools/ImageTrimmer.rb:769 C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/SKMtools/ImageTrimmer.rb:238:in call'
                                  MADE, BORN AND LIVING IN BERLIN
                                  Big Thank You to all Programmers
                                  Some German words are so long that they have a perspective. M.Twain
                                    @deaneau
                                    Check you have full read/write security permissions to your Plugins folder and the contents... Temporary files are written into the SKMtools subfolder etc...
                                    I suspect that the error is occurring because you have non-ascii characters in the name of something - the Image or the SKP itself ?
                                    Are you DE ?
                                    Do not use accented letters in file/folder names.
                                    Ruby can fail to find files etc if you do - it's a known limitation of SketchUp's Ruby n PCs...
                                    • deaneauD Offline
                                      deaneau
                                      Hello TIG
                                      nothing is happend.
                                      all file i write without accents.
                                      i have try to remove the write protection at first was ok, however when i open this dialog again the writeprotection is ON again.
                                      the same problem i have with sketchup make
                                        You'll need admin rights...
                                        Control Panel > Users - make yourself and admin.
                                        You MUST have FULL rights to the Plugins folder to do thing with this tool, AND many other tools for that matter ! ...
                                        Select the Plugins folder's icon
                                        Right-click
                                        Context-menu
                                        Properties
                                        Security
                                        Edit
                                        Set each user/group that is listed to have FULL, read/write permissions.
                                        Apply & OK to save...
                                        The changes ought to filter down to all enclosed files and subfolders automatically - but please check the permissions on the tools folder etc...
                                        Next...
                                        Right-click
                                        Context-menu
                                        Properties
                                        Compatibility
                                        Tick the 'Always run this application as an administrator' box
                                        Restart SketchUp and retry the tool to see if it now works...
                                        • deaneauD Offline
                                          deaneau
                                          done everything , nothing works
                                            Not very useful information.
                                            What happens?
                                            What is created?
                                            Are there error messages in the Ruby Console.
                                            What us the exact name of the SKP, the Image and the containing folder of the SKP ?
                                            Do you have full permission to this containing folder AND to the ../Plugins/SKMtools subfolder [and all of its contents] ??
                                            Please post all of this...
                                            I still feel it's either a permissions issue and/or a filepath naming problem...
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 18
                                            • 19
                                            • 12 / 19
