    โš ๏ธ Important | Libfredo 15.6b introduces important bugfixes for Fredo's Extensions Update
    [Plugin] Save Copy As Previous Version
    60 Posts 22 Posters 67.5k Views 22 Watching
    • U Offline
      unsuns
      I did a few more tests and I figured out what the problem is :
      I used to try to overwrite the active file from v2016 to save it as v8 through the plugin-> Same name (Format : %model).
      However, when I added some other character (Format: %model_V8), meaning that it saves as another file, this works perfectly, and Lumion reads the file flawlessly.
      So, the real issue is : Can we FORCE the plugin to overwrite the current and active SKP v16 file in order to make it v8 ?
      Thank you.
      EDIT : Indeed, I just had to change the "Sketchup.active_model.save_copy" to "Sketchup.active_model.save". Now it works PERFECTLY !
      PROBLEM SOLVED ! THANKSSS ! ๐Ÿ˜„
        stagelight
        I just posted this. Maybe this will useful..
        http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=63606
          rv1974
          Jim may I humbly request a sub-version of your 'Save Copy As Previous Version' that would save only selectedin v8 format and would preserve coordinates.
          Desirabaly it should save from inside hierarchy,
          save silently (no pop-ups)to the same parent directory, and add some kind of suffix '_v8' in the file name.
          Thanks in advance.
            Jim
            Hi rv I'll see what I can do but it likely won't happen until this weekend.
              Jim
              Thanks in advance.
              I am not sure I understand what you need. We have also exchanged some private messages which have only confused the issue for me. Can you explain in more detail what you would like to do? What problem needs solved, or what work-flow could be more efficient?
                rv1974
                Please see attached scrinshot+ skp files.
                In file 1 I select all instances of tree and red curtain components and (hopefully) your new script would create (silently, in the same folder, origin preserved) 1_say_jim_v.8 skp file containing all of them.
                Thanks.
                jim.zip
                  Jim
                  Would it make sense to be able to right-click a single instance of a component and create the _v8 file?
                    rv1974
                    Would be completely OK.
                      Jim
                      What I have done thus far is this:
                      Right-click one component instance from anywhere in the model hierarchy, then select "Save all Instances"
                      The plugin saves the component to disc in the same folder as the original model as a .skp file. The plugin goes through the model and writes the positions of each of the instances in the model to a text file with the same name as the component i the same folder.
                      Now you have the option to use the "Import Instances" in the Extensions menu. You can import to the same model, or to a new model. All instances are imported to the same location as in the original file, but they are all at the Model context. You can then manually save imported components file as a version 8 file.
                      I am still working out how to best create the version 8 file containing only the selected components from the original model. I hope this helps for now. I plan on continuing work as time permits.
                      jf_save_instances.rb
                        rv1974
                        Awesome! I had no chance to check it out today, gonna try it tomorrow
                        Many thanks in advance!
                          rv1974
                          Tried it right now and I happy to confirm this is awesome tool โ˜€
                          I highly recommend to all good people of Sketchucation to adopt it their arsenal.
                          Briefly it serves to grab the instances of entourage randomly delete\diversify them
                          just with a couple of clicks.
                          Jim many thanks once again.
                          P.S. Should we expect v8?
                          P.P.S. It appears there's a free bonus- the script 'fixes' the bug of 3ds Max that in bizarre way flips the instances originally mirrored in SU. So when you insert v8 skp file
                          into the Max all items look OK.
                            rv1974
                            Jim don't forget to put it into PluginStore as separate tool
                            • jujuJ Offline
                              juju
                              Jim, correct me if I'm wrong, but a little tweaking this could very well work as a proper proxy plugin?
                              All you need is to provide the component instances of high poly and low poly and have it swapped out using the script?
                              The location for the saving of the instances might need customization depending on whether or not the component instances are unique to the model or library items.
                              An interface (like layerspanel or outliner perhaps) for easier component management might also be useful if it develops into a commercial plugin.
                                rv1974
                                Or, it could turn to some king of Skp Xref Manager.
                                • jujuJ Offline
                                  juju
                                  TIG already did a plugin for XREF, it works great but the interface needs scrolling bars (which he isn't keen to implement due to time/coding implications)
                                    rv1974
                                    Never could make it (the TIG's one) work for me. Just gave up
                                    • P Offline
                                      pcucka
                                      Hi there!
                                      For some reason I cannot seem to install this plugin on SU 2015.
                                      Thoughts?
                                      • sdmitchS Offline
                                        sdmitch
                                        @pcucka said:
                                        Hi there!
                                        Thoughts?
                                        Since this a '.rb' file, it can not be installed as an extension.
                                        option 1 is to simply copy it to the Plugins folder and restart Sketchup. You should find '[jf]Save Copy As ...' under Files.
                                        option 2 is to Zip the .rb file and change the .zip extension to .rbz. This file can be installed as an extension.
                                        I was able to load and use this plugin in SU2015.
                                        http://sdmitch.blogspot.com/
                                        • bigstickB Offline
                                          bigstick
                                          This is a really useful plugin - thanks!
                                          One small request which many people might find useful - would it be possible to have a right-click menu to save an individual component as a previous version?
                                            rv1974
                                            TIG, what in save-copy-as-2.0-jf.rb should be changed in order to save the file in older version (2015) withoutaltering its name? Ideally, pop-up window with ' the File file with the same name exists, do you want to replace it?' should be suppressed as well. In short, regular Save command (but to v2015).
                                            • 3 / 3
