    [Plugin] Save Copy As Previous Version
    60 Posts 22 Posters 70.2k Views 22 Watching
      rv1974
      Please see attached scrinshot+ skp files.
      In file 1 I select all instances of tree and red curtain components and (hopefully) your new script would create (silently, in the same folder, origin preserved) 1_say_jim_v.8 skp file containing all of them.
      Thanks.
      jim.zip
        Jim
        Would it make sense to be able to right-click a single instance of a component and create the _v8 file?
          rv1974
          Would be completely OK.
            Jim
            What I have done thus far is this:
            Right-click one component instance from anywhere in the model hierarchy, then select "Save all Instances"
            The plugin saves the component to disc in the same folder as the original model as a .skp file. The plugin goes through the model and writes the positions of each of the instances in the model to a text file with the same name as the component i the same folder.
            Now you have the option to use the "Import Instances" in the Extensions menu. You can import to the same model, or to a new model. All instances are imported to the same location as in the original file, but they are all at the Model context. You can then manually save imported components file as a version 8 file.
            I am still working out how to best create the version 8 file containing only the selected components from the original model. I hope this helps for now. I plan on continuing work as time permits.
            jf_save_instances.rb
              rv1974
              Awesome! I had no chance to check it out today, gonna try it tomorrow
              Many thanks in advance!
                rv1974
                Tried it right now and I happy to confirm this is awesome tool β˜€
                I highly recommend to all good people of Sketchucation to adopt it their arsenal.
                Briefly it serves to grab the instances of entourage randomly delete\diversify them
                just with a couple of clicks.
                Jim many thanks once again.
                P.S. Should we expect v8?
                P.P.S. It appears there's a free bonus- the script 'fixes' the bug of 3ds Max that in bizarre way flips the instances originally mirrored in SU. So when you insert v8 skp file
                into the Max all items look OK.
                  rv1974
                  Jim don't forget to put it into PluginStore as separate tool
                  • jujuJ Offline
                    juju
                    Jim, correct me if I'm wrong, but a little tweaking this could very well work as a proper proxy plugin?
                    All you need is to provide the component instances of high poly and low poly and have it swapped out using the script?
                    The location for the saving of the instances might need customization depending on whether or not the component instances are unique to the model or library items.
                    An interface (like layerspanel or outliner perhaps) for easier component management might also be useful if it develops into a commercial plugin.
                      rv1974
                      Or, it could turn to some king of Skp Xref Manager.
                      • jujuJ Offline
                        juju
                        TIG already did a plugin for XREF, it works great but the interface needs scrolling bars (which he isn't keen to implement due to time/coding implications)
                          rv1974
                          Never could make it (the TIG's one) work for me. Just gave up
                            pcucka
                            Hi there!
                            For some reason I cannot seem to install this plugin on SU 2015.
                            Thoughts?
                            • sdmitchS Offline
                              sdmitch
                              @pcucka said:
                              Hi there!
                              Thoughts?
                              Since this a '.rb' file, it can not be installed as an extension.
                              option 1 is to simply copy it to the Plugins folder and restart Sketchup. You should find '[jf]Save Copy As ...' under Files.
                              option 2 is to Zip the .rb file and change the .zip extension to .rbz. This file can be installed as an extension.
                              I was able to load and use this plugin in SU2015.
                              http://sdmitch.blogspot.com/
                              • bigstickB Offline
                                bigstick
                                This is a really useful plugin - thanks!
                                One small request which many people might find useful - would it be possible to have a right-click menu to save an individual component as a previous version?
                                  rv1974
                                  TIG, what in save-copy-as-2.0-jf.rb should be changed in order to save the file in older version (2015) withoutaltering its name? Ideally, pop-up window with ' the File file with the same name exists, do you want to replace it?' should be suppressed as well. In short, regular Save command (but to v2015).
                                  • 3 / 3
