    Photomatch model from interior render?
    2 Posts 2 Posters 326 Views 2 Watching
    • N
      nickdk
      I'm having a really hard time getting an interior photomatch succes! I'm not sure how to define how the SU model is rotated? When I start to adjust the red and green perspective lines, the model starts to rotate and when I have placed the perspective lines I see the model from the back hmm? πŸ˜’
      I can load the SU Scene i used for the render, but I need the model to stay in the exact same position in regards to the perspective so I can zoom out and keep everything as it was at render time and it seems to be very difficult?
      • dereiD
        derei
        Be sure you select the correct projection, according to your model (image). Also, be sure that you have front view activated, not back view, in sketchup viewport. If green axis is with dotted part towards you, is OK. But if the dotted line is pointing at the horizon, you are looking to your model from back and that can explain why you are seeing the model that way.
        DESIGNER AND ARTIST DEREI.UK
