    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Spot heights (AutoCad) to Contours (Sketchup)
    2 Posts 2 Posters 2.3k Views 2 Watching
    • W Offline
      wloveland
      I have been given a survey with a series of spot heights, I need to create 3D terrain from this, I need to make these contours so that I can use them in sketchup.
      In the autocad file I have removed everything but the spot heights, by spot heights I mean a 2D image of an (x) with the height in metres next to it.
      I have then run a program on AutoCad that recognizes the text and crosses and gives them a height (Z) value turning it into a 3D connect the dots haha.
      This is where I encounter the problem when i try to import this into sketchup and use contours it does not recognizes it and nothing happens.
      Anyone have any advice?
      I can upload the files if you need to see it in more detail.
      Thanks.
      • H Offline
        Howard leslie
        It's quite old now and not the only way to achieve what you want:
        http://forums.sketchucation.com/viewtopic.php?f=18&t=4276
        I hope it helps you though
        Regards
        Howard L'
