    Easiest way to skin/weld a kazillion little lines
    6 Posts 2 Posters 465 Views 2 Watching
      davesec
      hi!
      i imported a .dwg file of some topography into sketchup. it's one enormous group. i'm not sure if i can explode it, the computer just hangs after a while - i'm guessing this is because there are about a billion lines involved.
      does anyone know if there's an easy way to turn these tiny segments into something useable? is there a better way to export this from autocad? ideally i'd like to just weld/skin these segments into landscape that i can build on.
      thank you!
        If you edit the group, you can triple click on a segment and all connected edges willl be selected. Then you can run the Weld.rb plugin. But why not use the Sandbox > From contours tool (with or without welding)? This is exactly what it is for.
          davesec
          hi!
          okay, so by cutting down what i export out of autocad, i've been able to explode groups. by using the weld tool i've been able to turn them into a series of 2d shapes that are at the proper elevations (see attached). any idea on how to skin this? i'm having trouble doing this with curviloft, and i'm wondering if it's because the shapes are too complex?
          thanks!
            davesec
            hi gaieus - i missed your post! i will give it a shot, i'm not overly familiar with the sandbox tools. will post back with results.
            thank you!
              davesec
              well that was too easy - apologies for such a simple question, i wasn't aware there was such an easy solution!
              thanks again!
                Glad it works (sometimes it can be tricky)
