    [Plugin] Simple Shell (scaled copy)
    38 Posts 12 Posters 42.6k Views 12 Watching
      Yes I have the Menu JF Simple Shell πŸ˜‰
      Here the code in Ruby Console after I select the group and call the plug by the Menu
      and enter some measures in the Dialog box
      (same result with the direct Ruby console commands)
      Error; #<ArgumentError; wrong number of arguments(2 for 1)>
      C;/Program Files/Google/Google SketchUp 6/Plugins/jf_simple_shell.rb;30;in `start_operation'
      C;/Program Files/Google/Google SketchUp 6/Plugins/jf_simple_shell.rb;30;in `simple_shell'
      C;/Program Files/Google/Google SketchUp 6/Plugins/jf_simple_shell.rb;2
      C;/Program Files/Google/Google SketchUp 6/Plugins/jf_simple_shell.rb;2;in `call'
        Works fine now in the V6 😎
        You rocks! πŸ‘
        I don't retry with the V8 and V7 πŸ’š
        Edit : works also with the V7 πŸ˜‰
          Jim
          @Dave, I would like to keep the created shell as a Group. This is so the operator can make sure the shell does not intersect with anything else before moving on. There may be scaling or other adjustments (snoothing, reverse faces) that should be done, too. This allows the operator the most choices on the next action.
          One small thing I will have the plugin do is to select the created shell Group as the last step. Then at least it is ready to explode if you want.
          For shelling a Component, right now you could open the Component, select all, make it a Group, shell it, then explode again. I know it's not optimal, but is one way to do it.
          It's possible to make the plugin work on a selected surface as well as a selected Group, so then you could open the Component, make the selection, and generate the shell; which is fewer steps. This is something I want the script to do, so it'll be available soon either way.
            dtrarch
            Hi Jim
            FYI: ?
            I get this error loading SU 7.1 free with the script installed per your first thread posted.
            Error Loading File jf_simple_shell.rb
            C:/Program Files/Google/Google SketchUp 7/Plugins/jf_simple_shell.rb:1: syntax error
            <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
            C:/Program Files/Google/Google SketchUp 7/Plugins/jf_simple_shell.rb:2: syntax error
            <html xmlns="http://www.w3.org/1999/xhtml">
            C:/Program Files/Google/Google SketchUp 7/Plugins/jf_simple_shell.rb:3: syntax error
            <head>
            C:/Program Files/Google/Google SketchUp 7/Plugins/jf_simple_shell.rb:5: syntax error
            <title xmlns="http://www.google.com/ns/jotspot">Download Attachment</title>
            C:/Program Files/Google/Google SketchUp 7/Plugins/jf_simple_shell.rb:6: syntax error
            <style xmlns="http://www.google.com/ns/jotspot">
            C:/Program Files/Google/Google SketchUp 7/Plugins/jf_simple_shell.rb:19: syntax error
            content: ".";
            C:/Program Files/Google/Google SketchUp 7/Plugins/jf_simple_shell.rb:70: syntax error
            <body xmlns="http://www.google.com/ns/jotspot">
            dtr
              Jim
              dtrarch,
              That looks like a HTML file.
              Try right-clicking this link, then select Save Link As (or Save Target As) to download the file.
                Jim
                Updated to create a shell from selected surface, in addition to a selected Group.
                See First Post.
                  Cool! But the same with scale from a opposite point will be also useful πŸ˜‰
                    dtrarch
                    Jim
                    Somehow I did download the html. 😳
                    Your link worked perfect and thank you so much 😍
                    OK for SU V8 pro too.
                    Very handy tool. πŸ‘ πŸ‘
                    Dave #2
                      sahi
                      Cool. It reminds me my old Object πŸ˜’
                      here: http://forums.sketchucation.com/viewtopic.php?f=180&t=11677
                        Jim
                        Thanks sahi,
                        Yes, my plugin is almost exactly the same as yours - I may not have written another if I knew one already existed.
                        One reason it couldn't be found is the topic lacks the [Plugin] text that is used by the Plugins Index, and so is not listed. I have requested the mods add the tag so the plugin will be listed.
                          sahi
                          That's my fault. I have not posted it here. (But that was long ago 2008)
                          • McGyverM Offline
                            McGyver
                            Thank you very much! I can see many uses for this plugin!!
                            Visit My ShareCG Freebie Gallery
                            • U Offline
                              unclex
                              Group Many times,but can;t work……
                              at last
                              it works on the component……
                              why。。。。。。。。。
                                Jim
                                @sahi: Your Scale to_cm plugin is now listed inthe Index.
                                @unclex: I need more information. Open the Ruby Console Window, then use the plugin. Are there any errors displayed in the Ruby Console?
                                  Yesterday I start fiddling around with a small test project that thickens a surface. I've not uploaded it here at SCF yet, but it's available at BitBucket if you should be interested.
                                  https://bitbucket.org/thomthom/shell/
                                    Jim
                                    It works well on the simple stuff I just tried it on. Very cool, thanks. (Now, I make a request about Solid Inspector...)
                                      Let me know of cases where it is not working so wwell. I have also trief only with simple stuff.
                                        Updated the Shell plugin with a tool. Also available for users here at SCF: http://forums.sketchucation.com/viewtopic.php?f=323&t=39308
                                        • 2 / 2
