    Why does scale bottom out at 0.11 instead of 0.1?
    2 Posts 2 Posters 412 Views 2 Watching
    • E
      Ecuadorian
      Just wondering...
      Why, when you scale down an object, it bottoms out at 0.11 instead of 0.1?
      -Miguel Lescano
      • J
        Jim57
        Ecuadoran—
        Wile the answer to this and many other questions remain shrouded in the realms of mystery, you can select an object, Scale, start to move a control point, and then type in the percentage or size you want to end up with. If you are shooting 0.1% (or less, say 0.01), just grab a control point and move it a bit, then type in a number. Less than one shrinks, more than one expands, negatives make mirror images. If you add a unit of length afterwards, it scales that dimension to the number you typed, as in 1mm; 3.5"; .7m; 42'.
        Best,
        JIm
