    Explode to Individual Components / Groups ???
    4 Posts 3 Posters 379 Views 3 Watching
    • H Offline
      Howard leslie
      Hello,
      Does anybody know if a script exists to break a model down to individual Groups / Components ???
      It would need to mine down inside all groups and components (no matter how deeply nested).
      No loose geometry to be left.
      What you'd end up with is best seen by looking at the Before and After attached JPGs
      (Have a look at the Outliner)
      Ideally it would work on seriously massive / complex models
      Hope this makes sense
      Any help anyone can give much appreciated
      Regards
      Howard L'
      Before
      After
      • honoluludesktopH Offline
        honoluludesktop
        If you removed the association of nested instances from their parents, you would not be able to move the interior instances when you moved the parent. Or are you looking to explode nested instances, but allow them to retain their association with the parent instance?
        • H Offline
          Howard leslie
          I'm not worried about breaking links with parents.
          See "After" JPG (especially the outliner)
          Further processing will be done on the singular groups / components afterwards.
          Howard L'
            chrisjk
            Not quite sure if this is what you are after but might help?
            http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=38
            or this
            http://www.smustard.com/script/Exploder
            Chris
