    E-on Vue Xstream for architecture
    extensions
    3 Posts 3 Posters 1.9k Views 3 Watching
    • Z Offline
      zeeshan
      I am new to photo realistic rendering and not as good as experts here, however this is my first rendered building design using Vue. I designed if for my client. its a big complex for "ZONG" in Pakistan, Kindly suggest improvements if you may.
      thanks
      • E Offline
        elgamed88
        how does the vue render works on sketchup ?
        • Chris FullmerC Offline
          You can purchase a SketchUp exporter that takes your file and saves it to a Vue file. THen Vue opens it and you can use it in Vue. You can add trees and plants in Vue, or whatever you want to do in Vue. Then render.
          If you don't want to pay for the plugin, you can also export from SU as a .obj file, then open that in Vue and it comes in fairly well much of the time.
          Chris
          All my Plugins I've written
