π¨ Skimp | 25% Off until March 30 Buy Now
Cutting_Windows installation problem
Hi All
Today I try install many plugin's.
Everything is ok except one.
When i try instal Cutting_windows english or frnace wersion shows error
"...Error Loading File cutting_windows.rb
(eval):719: compile error
(eval):610: syntax error, unexpected ',', expecting kEND
faces_and_heights[0].pushpull (faces_and_heights[1]), false
^Error Loading File fr_cutting_windows.rb
(eval):709: compile error
(eval):606: syntax error, unexpected ',', expecting kEND
I have SU 8Miecho
Due to update in the Ruby engine in SU8 some syntax errors that was ignored in SU7 now throws an error in SU8. Check with the author of the plugin if there is an update available.
