    Global coordinates Question
    4 Posts 3 Posters 528 Views 3 Watching
    • B
      Brett McAllister
      Hi Guys
      Quick question,
      I am creating a tool which uses the pick helper class.
      When I use the picked face method to find the surrounding vertices within a closed group or component , the positions are returned as local coordinates.
      Is there a method within the API to change the values from local to global.
      I tried some of the transform methods but it's all rather vague and I am not having any luck, if anyone has any suggestions it would be greatly appreciated.
      Cheers
      Brett
      • TIGT
        Something like...
        entities.transform_entities(group.transformation, array_of_points_or_vertices)
        untested...
        Where entities is the model.entities [or 'active_entities'?], group is the parent of the point/vertex and the 'array' is the list of things to 'transform'...
        'Nested' groups etc need a transformation for each context...
        • J
          Jim
          The final transformation is the combination of all the parent transformations. So if you have a Group3 nested as follows:
          + Model
            + Group1
              + Group2
                + Group3
          Then the Transformation for entities in Group3 is:
          final_trans = Group1.transformation * Group2.transformation * Group3.transformation
          • B
            Brett McAllister
            Thanks for the help,have got it sorted.
            Jim - I really appreciate you sharing the info about the nested components/groups saved a lot of time and effort
            Brett
