SU7
Is it still possbile to downlaod SU7 from anywhere? (I have SU8 pro installed already.
Here they are:
http://sketchup.google.com/support/bin/answer.py?hl=en&answer=60107
You may experience issues installing an older version after a newer version however. In this case uninstall SU 8, install SU older and then install SU 8 again. -
Hi folks.
You can probably save the uninstall and reinstall of SU 8 with this trick:
Rename the "Google SketchUp 8" folder. Use "SU 8" for example or just add -1 or whatever to change its name.
Install SU 7. Normally it should install in a separate directory.
When done, rename the SU 8 directory to its former name.
You now have both versions available.
Just ideas.
Register LoginAdvertisement
