    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    To sketchdata
    extensions
    5 Posts 2 Posters 1.1k Views 2 Watching
      dedmin
      I tried the Attribute Update Simple/Complex plugin, but it only accepts inches as a input data even the attributes settings are in centimeters. Thanks - the plugins are really time savers.
        sketchdata
        Thanks for the feedback, currently working on a new attribute update plugin that uses models units. The new plugin will also try to resolve the problem with the built in "Component Options" window, which doesn't update the dynamic attribute library for LenX, LenY, LenZ changes when a component is Stretched or Push/Pulled. What do you think of a "remove formula" option? Thinking it will make the DC unique and then remove any formulas, making the attributes more open to manual changes?
          dedmin
          Thanks - keep up the good work! Can You be more specific about "remove formula" - where is this option?
            sketchdata
            I will add the "remove formulas" option to the new attribute update plugin, which will use the "display/model" units vs. the default inches. Hopefully within a week or so...Thanks...
              dedmin
              I see. Waiting to test the new version πŸŽ‰ πŸŽ‰
