    Lines problem
    3 Posts 2 Posters 249 Views 2 Watching
      albeone
      Hello everyone. is just that I use sketch-up.
      I have a problem. how to join two lines into one line?
      .__
      thanks for your attention!
      albe
        Hi Albe (and welcome),
        It depends if they are co-linear (i.e. should be one straight line but is broken by an endpoint) or not and only should be welded into a polyline.
        If the first, just draw a connecting line from that endpoint and delete it. It will also "heal" the other two lines into one. There are good plugins for this, too.
        If the latter, use Weld.rb plugin.
          albeone
          thaks guy!i'll try
