    How to make transparent alfa mask texture - SU?
    10 Posts 5 Posters 3.3k Views 5 Watching
    • jarynzlesaJ
      jarynzlesa
      I couldn't find tutorial how to make transparent alfa mask texture.
      Does anybody know where I could find it, If exist?
      Example textures.
      Tree
      tree_alpha
      http://www.vizualizaceschodiste.mypage.cz/
      • GaieusG
        Hi jarynzlesa,
        That png is already transparent. Do you mean how to make that one or how to make the alpha? Or actually, how to start from scratch (from a photo you take)?
        • andybotA
          andybot
          Are you looking to make a separate image file with the alpha layer? In Photoshop - you would go to "layer -- layer mask -- from transparency" This way you get an new alpha channel that you can save into a new image. I can explain further if that's what you're looking for.
          • jarynzlesaJ
            jarynzlesa
            Sorry for misunderstanding. This is my fault. Problem solved.
            I'm idiot. πŸ‘Ž
            • GaieusG
              So what exactly was that problem?
              • jarynzlesaJ
                jarynzlesa
                I didn't create layer mask.
                Thank you for comments πŸ‘.
                without layer mask
                problem_solved
                • D
                  d12dozr
                  You can hide the outside edges to make the 'bounding box' invisible...
                  http://goo.gl/f7ooYh
                  • jarynzlesaJ
                    jarynzlesa
                    Don't know what 'bounding box' is but I got rid of those edges (erase + shift).
                    Thanks for advice 😎 .
                    Works
                    • D
                      d12dozr
                      That's what I meant πŸ˜‰ A little faster way to hide those lines is to double click the face so the face and edges are selected, then shift-click the face once to DE-select just the face(this leaves all the edges selected). Then hide the edges all at once -- I have 'hide' set as a keyboard shortcut, or right click > Hide.
                      To be precise, a bounding box is the dotted gray lines that surround a group or component when its open for editing, or the blue lines that appear when a group or component is selected.
                      Your plant looks great!
                      • R
                        rspierenburg
                        I usually have a 'hidden' layer setup by default, and place all those boundary lines on that and just turn it off.
