    VCB Clipboard?
    5 Posts 3 Posters 594 Views 3 Watching
    • EarthMoverE
      EarthMover
      Is there a plugin or method to copy the contents of the VCB to the clipboard and then paste it into another tools VCB? It would be great to assign a shortcut to do this so if I'm using say the tape measure tool, I could copy the distance, then paste it into the VCB for other tools.
      Content Creator at Skapeup
      • jeff hammondJ
        jeff hammond
        i use the tab key for that (tab highlights the vcb instead of mousing to it)
        simple example:
        draw a line
        push tab
        ⌘C (ctrl-C windows)
        draw another line
        ⌘V
        return
        [i'm not sure if the tab key does the same thing on windows]
        dotdotdot
        • EarthMoverE
          EarthMover
          In windows, TAB seems to just clear the VCB. I can't select the measurement reading at all to copy it. It would great if it were that simple. Must save a lot of time on a Mac doing it that way.
          • W
            watkins
            Dear Adam,
            Not quite what you want, but you could use cut and paste from the Entity Info box.
            Regards,
            Bob
            • EarthMoverE
              EarthMover
              Thanks Bob, but you can't paste into the VCB that I can tell.(?) Also Entity info box doesn't work with Tape Measure tool guides. I was guessing it would have to be done via ruby script, which is why I put the thread here and not in the general discussion area. I'm pretty sure the VCB is accessible via ruby, as someone made a calculator with it, I just don't know if you can glean and store a number and then reinsert it.
