    ComponentInstance.explode
    5 Posts 3 Posters 449 Views 3 Watching
    • honoluludesktopH
      honoluludesktop
      In an array of 4 component instances from one definition, the following snippet:
      entities.each do |ent|
        if ent.is_a? Sketchup;;ComponentInstance
          ent.explode
      explodes 2 of the 4 instances. However the next snippet will produce 4 exploded instances.
      ci_ent=[]
          ci_ent.push ent
      ci_ent.each do |ci|
        ci.explode
      Can anyone tell me why the first snippet doesn't work?
      • Chris FullmerC
        What happens is that you are running .each on the active (and very volatile) entity collection. That is ok, but when you explode the components, SketchUp is adding entities to the entitiy collection - while you are trying to iterate over the whole thing with the .each method. SU does not keep track of what entities have been processed. My guess is that .each processes the entities collection as a list and does not notice that the exploding might have jumbled the order of the list, and certain entities (like those 2 component instances) got moved around in the list to where they get skipped over.
        Try running .each on an array of the entities collection like this:
        entities.to_a.each do |ent|
        or perhaps easier to read, but approsimately identical in practice:
        ent_array = etities.to_a ent_array.each do |ent|
        That takes the entities collection BEFORE anything is changed in the list of entities, turns it into an array (TIG has called it a "snapshot" of the entities collection before). But that array remains stable and orderly while the actual entities collection itself is getting jumbled up with new entities being added to it due to the exploding.
        This is also why your 2nd example works. It iterates through the entities collection and makes an array of what to explode - it does not change do anything (like explode) that would mess up the oreder of the entities collection. Then once it's done iterating, it explodes those items.
        Hope that helps,
        Chris
        All my Plugins I've written
        • honoluludesktopH
          honoluludesktop
          Chris, I now recall discussions on the forum about changing entities. This is the first time its happened to me, thanks for the reminder.
          • TIGT
            To recap:
            Never iterate through an entities collection that you are changing - because the collection changes as you go through it and then weirdness happens.
            Instead you should iterate entities.to_a as that is a 'snap-shot' of the entities collection at the moment you make that array.
            Another point is that if you are doing something like 'erase' inside the iteration use a test to see that the entitiy hasn't already gone - e.erase! if e.valid? - for example if you erase an 'edge' then its 'face' will go too, so later when you get to that 'face' in the array it will raise an error and stop the code dead if you try to simply e.erase! it because it's already gone !!! Another way is at the start of the iteration add next if not e.valid? so that entity is ignored.
            • honoluludesktopH
              honoluludesktop
              Thanks, gotit. Hope I don't forget!-)
