    Modelling backlit radio panel to ray trace
    4 Posts 3 Posters 615 Views 3 Watching
    • P Offline
      pootle
      I'm making up an old (1950's style) bakelite radio with a backlit panel. This technique I've already tried using su2pov and then pov-ray to generate a good picture of this, and it is quite promising, but I am finding it difficult to get an even illumination behind the panel.
      I thought a translucent panel (NOT transparent) would be a good way to do this - but there doesn't seem to be a translucent capability in su2pov.
      I've tried bouncing a light off a wavy metallic surface and this works reasonably well, but gets very slow once there are several panels involved.
      It might work to have a light surface in pov-ray, but as this works by having a number of point sources spread over surface I expect this would get very CPU intensive very quickly.
      What techniques / tools would you recommend to do this?
      • Chris FullmerC Offline
        Good luck with this one. I'm not sure how many die hard SU2POVray users there are around here these days. Hopefully they will all turn up soon though!
        Chris
        All my Plugins I've written
        • Didier BurD Offline
          Didier Bur
          Transparency is supported by su2pov (just use a transparent material in SketchUp).
          Tranlucency is a bit different, it can be achieved with Pov-ray but you'll have to tweak the material settings yourself...
          @Chris: su2pov 3.5. has more than 10.000 downloads since mid-June. I don't know how many users really use it πŸ˜’ ...
          DB
            Wowsers, many more than I had expected! It is not talked about all that much around here. I guesed people used it, but that is a pretty big number.
