    Close up view begins to disappear
    11 Posts 3 Posters 946 Views 3 Watching
      mrayula
      As i zoom into my model, the close up view begins to disappear from the bottom of the screen. A large component was implemented in the model, but i exploded it and deleted large portions of the componenet. But still as i try to zoom in, the veiw still disappears... and i can't get the view i want. Any suggestions on how to clean up my model and be albe to get the view i want without disappearing??? Please help
        Hi mrayula,
        This definitely sounds like clipping. That large component could be the culprit but exploding and deleting much of it may have not solved the problem.
        Have you got anything imported?
        Are there any hidden layers (with further, possible, extensive geometry)?
        Any chance to share the model?
          mrayula
          after a little viewing around, I agree clipping is my problem. I am stumped and need help. This is my first post, but find it a great source. How do i attach or share the file?
            Below the text area you are posting, there is a tab "Upload attachment".
            There is a file size limit however (I cannot remember exactly). Try and we'll see.
              mrayula
              34 mb, did it attach?
                No, that would definitely not attach (maybe 1/10 of it?).
                  mrayula
                  I have made the model as small as i can (and still 28MB, so there must be something still attached...?). How can i clean up the file more in sketchup so that it can be attached? Purge, compress, etc.? Any sketchup commands like this?
                    mrayula
                    I found purge. I am trying to get a close-up-view of view 1 (near the bridge), but the foreground buildings still disappear.
                    10-10-26 McPherson Sketchup Model.skp
                    • Jean LemireJ Offline
                      Jean Lemire
                      Hi Mrayula, hi folks.
                      You have a huge component that measure more than 20 miles across. It contains 79 edges but I have still not found what it is.
                      Get rid of it and your model will behave nicely. The extremely huge size of this component is what is stomping Open GL and causing the clipping problem.
                      To get rid of it, use the outliner and select the component named "10-02-03 - MCD ROADS.dwg". Once selected, delete it.
                      While in cleaning mood, you can also delete the 4 instances of Sang that are hanging near the axes origin.
                      Finally, I would suggest that you move the model so it is centered on the axes origin. This would minimize even more the risk of having any clipping problem.
                      Just ideas.
                        So the solution has been spotted - and it's indeed some imported stuff - thanks Jean.
                          mrayula
                          that was the problem, no more clipping. thanks!
