    How to paint a texture on a curved surface?
    2 Posts 2 Posters 664 Views 2 Watching
      Shinok87
      Basically, how do I paint a texture on a curved surface and have it look continuous. For example. I have a table top and I want to paint it a wood material. The table is circular with a rounded edge. When I select the edge it shows up as many many rectangular surfaces going around the table. I want to make all these surfaces just one surface. I am painting the texture by going to import .jpg "as texture". Any suggestions?
      Thank you.
        Hi Adam,
        You will have to "wrap the texture around" a curved surface like tha.
        Import it as texture on the table top with hidden geometry displayed (View menu). This will allow you to position the texture accurately (you cannot access the texture positionng tools on curved surfaces or groups/components).
        Once you applied this texture, right click > Texture > Position. If you are happy with its being positioned, don't do anything but press Enter (or right click > Done).
        Now turn off hidden geometry and while holding down the Alt key, sample the positioned texture from the face with the Paint tool. With this, you not only sample the texture itself but its UV properties (mapping), too.
        Now theoretically you should be able to click on the untextured areas with the Paint tool (Alt released) and they should receive the whole positioning.
        Sometimes this is not perfect though. Then turn on hidden geometry again and sample+paint, samlpe+paint the facets one by one (always sampling from the formerly painted one).
        Sounds painful but can be entertaining... πŸ˜’
