    [NEW]Sketchup 2 Vue
    extensions
    164 Posts 28 Posters 42.9k Views 28 Watching
    • Bob JamesB Offline
      Bob James
      I am unable to load a SketchUp model of a house into Vue 9. I'm attempting to use the SU2Vue ruby script in Sketchup 8 Pro.
      Upon completion of export from Sketchup, I get a .vob file and a folder with an .xml file, a .py file and many .jpg and .png files.
      I have set the Camera Height to unlocked and Point Sun at Camera disabled.
      I've also unchecked "Preserve size of natural elements at creation"
      If I use the Automation -> Run Python Script all I get is a large ball as the model.
      If I try to use File -> Load Object I get an error statement saying that it can't find the .tga file xxxxxx.tga. If I say no to it's query to look for it, Vue crashes.
      A truly distressing introduction to Vue 😒 πŸ˜’
      Error received when trying to load .obj file
      This is supposed to be a house!!! Results from Automation -> Run Python
      • KrisidiousK Offline
        Krisidious
        I have been using the Import option... not load or even Python...
        try that and report back... are you using 9? because I am using 8.5... this may be a 9 bug.
        By: Kristoff Rand
          d12dozr
          Bob,
          I use the Automation -> Run Python Script and it works for me, like Kris, I'm also using Vue 8.
          TGA is an image file, like JPG. Maybe you could try finding and deleting/replacing that material in the Sketchup file before exporting, see if that helps.
          http://goo.gl/f7ooYh
            Krisidious
            save a copy of your model and remove all materials, then try importing it into Vue. report back
            By: Kristoff Rand
              Bob James
              None of the materials exported are .tga: they are all .png or .jpg.
              When I try to import the .vob file I get the errors looking for 191_tx01_402.tga, etc. (there are eight of them - I have no idea what material/texture they are linked to).
              So I've tried:
              1. Automation -> Run Python Script [All that appears is a large sphere]
              2. File -> Load Object [asks for .tga, cancel->Vue crash]
              3. Import .vob [asks for .tga, cancel->Vue crash]
              Edit: I also have Vue 8 Complete and I get the same result with it. As a matter of fact, I get the error messages when I use Automation -> Run!!!
              I'm at a loss
                Bob James
                How do I do that: it's a big model with over 80 different materials 😲
                  Bob James
                  I made a simple model: cube with cylinder on top - no color/material/texture.
                  When I import it by any of the three methods all I get is a sphere!
                  But at least I don't get the .tga error messages.
                  Not very encouraging 😞
                    Bob James
                    @krisidious said:
                    do you have the new version or the update to the plugin?
                    What is the latest version of the plugin? I got mine along with Vue 8 Complete back in October.
                    I opened the ruby, but there is no date in it. I see a lot of \win32\ in it: I'm using 64-bit Win 7 Professional. Is that a problem?
                      d12dozr
                      64 bit should not be a problem, I'm using 64 bit.
                      FWIW, I made a simple model of a cube, textured it with a .tga image, and it imported into Vue just fine.
                      Bob, I can't think of anything else...have you tried emailing Dave Burdick? He posted his email address near the top of the previous page.
                        Bob James
                        @krisidious said:
                        their is a "remove all materials" plugin it leaves all groups and components but removes all materials recursively.
                        try it on the model and let us know if it comes in.
                        Thanks, I'll try that but if it won't even import a cube with no material......
                          Krisidious
                          there is a "remove all materials" plugin it leaves all groups and components but removes all materials recursively.
                          By: Kristoff Rand
                            Bob James
                            Used TT's great plugin "Materials Tools" and removed all materials and made sure all faces were front faces: All I get is a large ball in Vue9. 🀒
                              Krisidious
                              this has got to be some issue with Vue 9 can you go and install 8.5?
                              By: Kristoff Rand
                                miikka1978
                                I am also having some problems when trying to use Automated VuePython Scene Loader. If I import Sketchup model manually, everything works ok. But, when using Python script I get only Sphere and no other geometry is listed in Object list. I am using Sketchup 8 and Vue 8.40-04.
                                  d12dozr
                                  miikka, are you unlocking the camera height and unchecking "Sun face camera" in Vue like the Sketchup2Vue manual says?
                                    miikka1978
                                    Yes, I have done those changes according to the manual.
                                      d12dozr
                                      Well hopefully Dave has the answer...you could try emailing him if you haven't yet...
                                        thecravatman
                                        Dave et al, Can you shed some light on my predicament. I have SU to Vue exporter, SU 8 and Vue 9 Complete. I load vob file from SU and it shows up in the layer pane and I can see the materials but I can see the scene. I select it and right click to select 'frame selected object' but can see anything. I re-scaled the model in case this was a mm to m problem but to no avail. I unchecked 'preserve size of elements at creation' check box again to no avail. I have tried via the python script.
                                        This is so annoying as I can see that it has been imported, its just I can see or manipulate it. Any tricks? Thoughts or work around I have run out of ideas. I really need something like zoom extents or a positioning tool so that it fits in the scene where I want it.
                                        Please tell me that I am missing something obvious.
                                        Thanks T
                                          Bob James
                                          I have Vue 8 Complete and Automation -> Run Python Script works just fine as long as the exported model has no textures.
                                          This is an improvement over Vue 9, but to have to "emasculate" all of my models and then re-texture them in Vue is not a viable workflow πŸ‘Ž
                                          Besides that, this does not help with Vue 9 πŸ‘Ž πŸ‘Ž
                                            dburdick
                                            Hi Bob,
                                            Sorry to see the problems you're having. Can you send me an e-mail to
                                            dburdick@e-onsoftware.com with the model in a zip file so that I can take a look at it and see what the problem might be? It sounds like there might be corrupt texture file or something. There is a new update for the SU to Vue Plugin coming out later this week that might fix this problem.
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 6 / 9
