    [NEW]Sketchup 2 Vue
    extensions
    164 Posts 28 Posters 40.2k Views 28 Watching
      thecravatman
      Thanks for the upgrade info Dave. I used the latest down loads plus SU 7 & 8. I have had no luck reading the vob files so I have removed every vue version and cleaned my machine and intend to do a clean install when 9 is released. Max imports Sketchup really well now so with Xstream + the plugin I have two paths I suppose.
      Any thoughts on a machine spec? what do you use at e-on?
        dburdick
        Hi Tim, when you say "latest downloads" do mean Vue 8 or just the latest downloads of your earlier Vue versions?
        On the machine specs for Vue, I would recommend:
        64-bit multicore cpu - I like the quad cores I5 and I7 from intel
        8 GB of RAM at least
        a decent graphics card - GeForce 460 or better or Quadro 2000 or better
        Also, it might be nice to scrounge up a few machines to use as render nodes and build your own mini render farm.
          jpalm32
          I would like to see IES lighting for VUE.
          Great for landscape applications.
            dburdick
            @prisoner said:
            Using SU with Vue (plus l3dt for terrain creation) could be very interesting for me (rendering outdoor top view maps), but rendering with parallel perspective would be necessary. Does anybody know if Vue can do this by now? I tried Vue once 1-2 years ago and from what I can recall there was no way to render orthogonal views. Would be great if that changed. Vue master solo?
            Hi There. You can render orthagonal views in Vue, but it's currently limited to the size of the viewport. I can render out 1600 x 1024 orthagonals on my 1900 x 1280 screen.
            • P Offline
              Prisoner
              Thanks for the info. That's a shame because what I need is more like 8k x 8k. Could have been the perfect tool 😞
              • P Offline
                Prisoner
                  thecravatman
                  Thanks for the follow up Dave, I tried 8 complete and also 8.5 ple and trial version, don't tell me they only work with registered versions?
                  The pc spec is useful, I aim to start with 12 meg and move on to 24 when the system works well.
                    dburdick
                    It's entirely possible the SU to Vue exporter won't work with the trial versions because they are older build numbers than the registered versions - I need to check this - thanks for pointing this out.
                    • K Offline
                      KarolinaLundbladh
                      Hi Tim,
                      What version of Vue are you using? You must have Vue 8 or later (build # 51429 or higher) in order to read the exported .vob files. The problems experienced by others were those using the Sketchup 7 on the Mac which has a ruby problem. Sketchup 8 on the Mac and Sketcup 7 and 8 on the PC work just fine with the exporter.
                      On the upgrade options for Vue 8 Complete, you have the ability to upgrade to Vue 9 Complete when it becomes available. There is also a trade-in path where you can trade in you Vue 8 Conplete to Infinite for $495. In your case however, given that you are using Max 2011, I would recommend waiting for Vue 9 xStream (should be released in a couple of weeks). Vue xStream can work in standalone mode or as a Plugin inside of Max/Maya/XSI/Lightwave/C4D and it's fully integrated in with the render engines of those systems.
                      Hi Dave,
                      I have just purchased Vue 8 Studio + the SketchUp exporter. I'm using SketchUp 7 Pro on my Mac and Vue is not able to read the .vob files that I export from SketchUp. Can the "ruby problem" with SketchUp 7 on Mac be solved?
                        d12dozr
                        Hi Dave,
                        I see that Vue 9 Complete is due to be released soon, around the same time as the Vue 8 Complete sale is due to end (that makes sense, I guess πŸ˜„ ), so I want to ask for advice...
                        I'm going to purchase Complete, preferably version 9, is it going to be on sale or am I better off buying Vue 8 Complete and then upgrading to 9?
                        Also, that relighting looks awesome...will that be available in Vue 9 Artist versions?
                        Thanks,
                        Marcus
                        http://goo.gl/f7ooYh
                          d12dozr
                          there is no longer a version of SU7 available.
                          BTW, you can still get SU7 here: http://sketchup.google.com/gsu7/download.html
                          • soloS Offline
                            solo
                            Marcus, I believe the relight should be available with all versions as it works with the render post dialogue, I am using 9 inf (there is no lower version in the beta test group)
                            http://www.solos-art.com
                            • HieruH Offline
                              Hieru
                              I'm a little confused.
                              Is the new SU plugin compable with Vue 64?
                              www.davidhier.co.uk
                                d12dozr
                                Sweet, thanks Pete.
                                  dburdick
                                  @d12dozr said:
                                  Hi Dave,
                                  Thanks,
                                  Marcus
                                  Hi Marcus,
                                  Good question. You can save around $100 by buying either Vue 8 Complete ($299) or the Vue 8 Complete Architectural Bundle ($329) and then the Upgrade to Vue 9 complete is $199. The Standard List Price for Vue 9 Complete will be $599. There will not be a sale of Vue 9 products for quite while - probably not until mid 2011 or later.
                                    dburdick
                                    Yes, the Sketchup Vue Exporter runs with all Vue Platforms (Win 32, Win 64, Mac 32, Mac 64)
                                      dburdick
                                      @karolinalundbladh said:
                                      Hi Tim,
                                      Hi Dave,
                                      Edit: I just downloaded and installed an old eval version of SU7.1 Pro on the Mac and much to my surprise, the Vue Exporter works just fine. You need to make sure you are using a Vue Product with build number later than 51429. The latest Vue 8 products are at build number 52326 - so perhaps you need to download a Vue software update.
                                        d12dozr
                                        Great...thanks, Dave, I'll get the $329 bundle now. I chose that bundle because (among other things) it includes animation capabilities, which SU is lacking.
                                          The sale should really be extended - maybe SantaClaus would get me one!
                                          πŸ˜„
                                          • K Offline
                                            KarolinaLundbladh
                                            Thanks for checking Dave!
                                            My build number is too low (48976), however when I check for software updates (File -> Check for updates) Vue tells me that my software is up to date. I purchased Vue and the SketchUp exporter together so they should be compatible. Any idea what I should do to solve this?
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 4 / 9
