    [Plugin] Hidden Manager (08.Feb.2015)
    48 Posts 19 Posters 35.6k Views 19 Watching
    • schorradtS Offline
      schorradt
      oh right... i will check it out. thx
      do you mean "SCF Power Toolbar v1" or where can i find a new version?
      http://www.henryschorradt.de/
      • KrisidiousK Offline
        Krisidious
        I don't think there is a new one. I think this thread goes over the issues found in it.
        http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=52474%26amp;p=475625%26amp;hilit=+custom+toolbar#p475625
        By: Kristoff Rand
          schorradt
          I think it's more a problem of Toolbar extension. ! Or?
          please report error message if you get a conflict with my plugin. thx
            Krisidious
            Yeah, this has nothing to do with your plugin Henry. This was in response to this.
            Re: [Plugin] Hidden Manager (16.Feb.2011)
            Postby cozzolino13 » Fri Mar 11, 2011 3:50 am
            this doesn't work after install scf power toolbar
            By: Kristoff Rand
            • P Offline
              Pherim
              It doesn't seem to work with SU2015 64bit.
              • P Offline
                Pherim
                Has this been updated for SU2015 64bit? It appears to be working now, though with it installed, SketchUp crashes when I use SketchUV to triangulate faces which are not inside a group or component (quite the opposite of the problem that occured with Components Manager and RoundCorner, where Sketchup would crash when RoundCorners was used inside components).
                  Jim
                  This plugin needs an audit. It is well-meant, although careless compilation of code.
                    BMoffa
                    Great plug-in idea. However, I discovered a problem when working with one of my dynamic components when your plug-in is loaded. I started getting hard crashes of Sketchup when I change a parameter that changed the number of copies of a subcomponent. It is so bad that the bug-splat screen doesn't even display. Unloading your plug-in fixes the problem for me. I can send you the dynamic component if it will help.
                    I am using the Sketchup Pro 15.3.331 64-Bit.
                    • 3 / 3
