    Sound Studio
    12 Posts 4 Posters 1.5k Views 4 Watching
    • K Offline
      kev_N
      Having a play around with a few models of a Sound Studio, so building all products first to put in it. Shall keep posting as i go along πŸ˜„
      Kev
        Macker
        Looks nice but (and I might be the only person to say this) I'm from a music/recording studio background and I think you should base the mixing desk on a real one. Such as a Neve or SSL (solid state logic) desk, as they're the ones used in the worlds best recording studios.
        If you need any info at all on how mixers are laid out, let me know! haha
        Modelling looks great though πŸ˜‰
        Check out my blog @ http://macviz.blogspot.co.uk
        • K Offline
          kev_N
          Hey ye defiantly. Could you send me over a plan from above of how they are set out? i seem to need to put the sliders under the dials right? (you can tell im not from the mix industry) would be good then can build this model up?
          • K Offline
            kev_N
            I had a google search for some images and started to change the model a little to match the main layout features. Macker what do you think, going the right way now?
              Macker
              It's a tricky one to explain in terms of layout unless you know what i'm talking about, also it depends on the level of detail you want to go into.
              Basically a mixing desk is split into "channels", each channel has a seperate audio input and the audio "route" through the channel will start at the top and travel through the following sections;
              -Gain/trim
              -filters
              -dynamics
              -eq
              -auxilliary sends
              -mute/solo
              -main fader
              So for each channel strip you'll need those sections (i'll post up some links to various documents/photo's showing what they look like). I'd definately model each channel as a component because in reality that's what they'd be as they're almost always fully replaceable.
              You could go for an SSL Duality (much easier to find reference images of):
              http://www.solid-state-logic.com/music/duality/images/Duality_SE_Angle_large.jpg
              http://www.solid-state-logic.com/resources/gallery/Duality/Duality_SE_Overhead_Xlarge.jpg
              Also, their brochure contains images of the channel strip buttons (page 7): http://www.solid-state-logic.com/docs/Duality_SE_Brochure.pdf
              Ahhhh, just found another one for the SSL that shows exactly what's on the main section of the channel strip: http://www.solid-state-logic.com/docs/Duality_Drawings.pdf
              What you've got looks good but isn't necessarily "technically" correct - but most people probably wouldn't care about that though, I guess i'm just a stickler for accuracy haha.
              [edit: removed the Neve mixing desk as there's not really enough reference material to model from - definately go for the SSL!]
              • K Offline
                kev_N
                πŸ˜„ wow that helps alot, thanks, will take some time to get the model totally detailed and sketchup isnt the best after the amount of "bugsplats" πŸ˜„
                Thanks again mate
                Kev
                • K Offline
                  kev_N
                  Also im a Designer by degree so its good to get things on the right track and know why things are designed like they are. Believe it or no this board was to accompany my speakers design , got a bit carried away πŸ˜›
                    Macker
                    Lookin' good!
                      Ross Macintosh
                      Now you need a comfortable chair for the operator and couches for the groupies!
                      • K Offline
                        kev_N
                        Cheers, im working on a vocal area just out of shot. ye will have to model some sofas , working on the mic and the headphones at mo too. shall keep them posted.
                        • michaliszissiouM Offline
                          michaliszissiou
                          Nice renders here!
                          But having some experience on sound problems, for better low-mid frequencies...
                          • K Offline
                            kev_N
                            Ok shall take a look at the curve change. Learning lots doing this. After all its just a bit of fun πŸ˜› but like to make it right πŸ˜„
