    Curviloft to do this or TIG's tools...?
    7 Posts 3 Posters 982 Views 3 Watching
    • utilerU Offline
      utiler
      Hey guy, I don't do much free form modelling but want to learn a little more about these tools.
      Say I want to model the following. [see attached] I want say the bottom third to be have a 'bulb' shape simmilar to the image.
      I've just done a simple follow me to explain.
      I have tried the Loft by spline too but doing something wrong... i end up with nothing.
      CurviLoft.skp
      Just Curious...
      • utilerU Offline
        utiler
        Ok I see. thanks Frenchy.. I seemed to be doing something wrong.....
        I'll keep playing.
        πŸ‘
        Just Curious...
          With a path maybe you must take only 2 faces?
          (I am not sure) πŸ˜„
            and
            (Loft Along Path is still not fully functional).
            πŸ˜‰
            • utilerU Offline
              utiler
              Cheers mate. πŸ‘ πŸ‘
              Just Curious...
              • EarthMoverE Offline
                EarthMover
                Andrew, you might also try TIG's Extrude Edges by Lathe. You can draw the profile, set the axis, change the rotation to 360 and set the sides. Should work well for that shape.
                Content Creator at Skapeup
                • utilerU Offline
                  utiler
                  Thanks Adam, I'll give them a try. I haven't loaded EE tools since upgrading to 8 but will do. I really need to work out what works best for organic modeling....
                  ta. πŸ‘
                  Just Curious...
