    OnRButtonUp broken?
    6 Posts 3 Posters 609 Views 3 Watching
      AdamB
      onRButtonUp only gets called if the mouse doesn't move, whereas onLButtonUp gets called when the mouse button is released regardless of whether the mouse has moved.
      ` class ButtonTest
      def initialize
      	puts "started"
      def onLButtonDown(flags, x, y, view)
      	puts "onLButtonDown"
      def onLButtonUp(flags, x, y, view)
      	puts "onLButtonUp"
      def onRButtonDown(flags, x, y, view)
      	puts "onRButtonDown"
      def onRButtonUp(flags, x, y, view)
      	puts "onRButtonUp"
      Sketchup.active_model.select_tool ButtonTest.new`
        Tested your code on Win7, onRButtonUp always trigger, even when I move the mouse after onRButtonDown triggers before releasing.
          tomasz
          It does work fine on Vista.
          Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
            AdamB
            ok, I've logged a bug with Google. Seems its just a Mac thing.
              AdamB
              Just for the record..
              On Mac, onRButtonUp doesn't get called apart from for a simple down-up click event. However, onRButtonDoubleClick gets called instead.. so just stick your code in there and things work.
              [Appreciated the super fast response from the Google Team]
                So both events are busted.
                And when they fix it..?
