Problem with view port
its probably a simple problem.. What are the greyed out sides for? how do i take them out. my other files are fine, it only appear on this file.
thankyou for your time
For those whom Imageshack does not load:
It must have been set by a plugin (there are different camera control plugins). Normally the Fix Aspect Ratio plugin should fix it.
If it's some V-ray result (and the above does not help), ThomThom has a plugin for that, too
enter this in on ruby console:
Sketchup.active_model.active_view.camera.aspect_ratio = 0.0
It will remove the grey parts...
Register LoginAdvertisement
