    [Req]Star Wars -TIE Fighter spherical cockpit
    5 Posts 3 Posters 2.9k Views 3 Watching
      stonebreaker
      hi,
      can anyone please make a tutorial how to make only the spherical cockpit with all of its details.
      here is a link of a great model which I found on the net: http://fractalsponge.net/gallery/Starfighters/TIE%20Fighter/index.html ( I know it's an 3dsMAX model) 😄
      a tutorial of how to edit a spherical object like a loudspeaker bowl would be cool too.
      I struggle with such objects.
      cheers and thx
      • numbthumbN Offline
        numbthumb
        Well, adding surface details on such spherical objects could be accomplished by Fredo6´s Tools On Surface, at least I think so - http://forums.sketchucation.com/viewtopic.php?f=323&t=11212&hilit=surface+tools+fredo
        Intersecting that "bowl" with another model could help in further editing.
        Comfortably numb...
          Why lost time to modelize that?
          You can load hundred models in SKP format of this here 💚
            stonebreaker
            You can load hundred models in SKP format of this heres 💚
            lol
            i want to learn to model something like that.
            Well, adding surface details on such spherical objects could be accomplished by Fredo6´s Tools On Surface, at least I think so - viewtopic.php?f=323&t=11212&hilit=surface+tools+fredo
            thx...that helped a little bit.
              numbthumb
              Just to add to that - Tools On Surface could help in engraving panel lines - if you don´t want to achieve that by textures, but to extrude such curved surfaces, another Fredo´s plugin could save you a lot of frustration http://forums.sketchucation.com/viewtopic.php?f=323&t=6708&hilit=joint+push+pull
              Comfortably numb...
