    Model Hierarchy
    2 Posts 2 Posters 650 Views 2 Watching
      spring.freediver
      I don't know if something like this has been posted before. If so, here's yet another one:
      This script prints a diagram of the model hierarchy to the Ruby Console.
      TIG and Thomas: line 46 of the script is to compensate for instance names being blank. The reason I though there was a bug is that in the Outliner window, the instance has a name.
      Thomas: Can you try this on a model that has the Group.parent bug in it? I wasn't sure if I needed to use the real_parent work-around since this is traversing the hierarchy as instances rather than groups.
      require 'sketchup.rb'
      if (not file_loaded?("PrintHierarchy.rb"))
          UI.menu("Plugins").add_item("PrintHierarchy") { printHierarchy  }
      file_loaded("PrintHierarchy.rb")
      def printHierarchy
         answer = UI.messagebox("Print Hierarchy to Ruby Console?", MB_YESNO)
         if (answer == 6)
            model = Sketchup.active_model
            #Sketchup.send_action "showRubyPanel;"
            h = ModelHierarchy.new(model)
            h.pdint(model)
            print("-------------------------------------------\n")
      class ModelHierarchy
      # Class to hold the model hierarchy, and example method to print diagram
      # Jeff RIchardson, October 2010
         attr_accessor ;definition, ;children, ;polygons
         def initialize(model)
            @definition = {}
            @children = {}
            @polygons = {}
            model.definitions.each do |comp|
               @polygons[comp] = 0
               comp.entities.each {|e| @polygons[comp] += 1 if (e.is_a?(Sketchup;;Face))}
               comp.instances.each do |inst|
                  @definition[inst] = comp
                  parent = inst.parent
                  @children[parent] = [] if (!@children.has_key?(parent))
                  @children[parent].push(inst)
         def pdint(key, level=0)
            printf("Model %s [%d polygons]\n", key.title, key.number_faces) if (key.is_a?(Sketchup;;Model))
            if (@children.has_key?(key))
               @children[key].each do |k|
                  name = k.name
                  name = sprintf("Instance of %s", @definition[k].name) if (name.empty?)
                  print("|   "*level)
                  printf("|---%s(%s) [%d polygons]\n", name, k.typename, @polygons[@definition[k]])
                  pdint(@definition[k], level+1)
        A definition.name applies to every instance, as in instance.definition.name - which can't be "" - but an instance ALSO has it's own name - which might be "" - instance.name ?
