    [Question] on transformation.rotation
    3 Posts 2 Posters 522 Views 2 Watching
      rvs1977
      Hi all SUdudes... πŸ˜„
      I have a problem rotating a component instance around itself from a chosen inputpoint.
      the component instance have been added, and then I want to rotate it:
      ip.pick view, x, y
      point = ip.position
      vector = Geom;;Vector3d.new 0,0,1
      angle = 2
      t= Geom;;Transformation.rotation point, vector, angle
      yv_instance.transformation = t
      I expected it to rotate around the point with the vector and rotate it 2 radians. BUT instead of rotating it around itself, it rotates around the ip-point and 0,0,0... hmmm hope you understand.
      the question is: How do I rotate a component around itself??? ❓
      tnx in advance πŸ˜„
      Get a Ruby
        The transformation
        t=Geom::Transformation.rotation(point, Z_AXIS, angle)
        [no need for another vector]
        and its use
        yv_instance.transform!(t)
        should rotate the 'instance' around the Z_AXIS centered on the point...
        The ' angle' should be in radians.
        You set it to ' 2' ? To use degrees try 2.degrees ...
        πŸ˜•
        Note how I have enclosed he arguments inside ( ) - the recommended way - as 'un-parenthesized' arguments might get deprecated in a future release of Sketchup's Ruby...
          rvs1977
          Great, thanks TIG!
          Now it works 😍
          Get a Ruby
