    Create zip files with sketchup ruby api
    4 Posts 3 Posters 1.1k Views 3 Watching
    • P Offline
      patriarch
      Is it possible to create zip file with SketchUp Ruby API?
      For example to make a SketchUp-LayOut bridge. The idea is to create a XML-file with the necessary dimensions and notes in sketchup. Then pack it in a zip file. Later you can open this file in LayOut and make changes in it or print the drawings.
        There is a separate mainstream Ruby 'zip' method... you need to find that and path it into your own Ruby - [re]distributing it with any install... πŸ€“
        • Dan RathbunD Offline
          Dan Rathbun
          Is that zlib.so ??
          I'm not here much anymore.
            That's one but there's also http://rubyzip.sourceforge.net/
