    Non-default scale?
    2 Posts 2 Posters 733 Views 2 Watching
    • D
      danbig
      What does this mean?
      I imported a DWG file (it came in as a component because there were other objects in the file).
      I copied, and pasted the component into a new document.
      I used the tape measure tool to resize the model.
      I right clicked on the component, selected "Save As", and this is the message I got:
      • GaieusG
        Since you scaled the component "from outside" (when resized the whole model), it has now a different size than the definition would have. SU is simply asking you if you want to save it like this (i.e. keeping this scale) or should it save it as the definitions defines its original scale.
