    Latitude/longitude not working ?
    3 Posts 2 Posters 456 Views 2 Watching
    • Didier BurD Offline
      Didier Bur
      Hi all,
      Has anyone ever got this working (out from the su-ruby api doc) ?
      Assuming you have set the georeference of your model in the Model Info dialog:
      coordinates = [10, 10, 10] # or whatever coordinate...
      model = Sketchup.active_model
      point = Geom;;Point3d.new(coordinates)
      latlong = model.point_to_latlong point
      latitude = latlong.latitude
      if (latitude)
      UI.messagebox latitude
      else
      UI.messagebox "Failure"
      It doesn't return a latlon object, but a point3d object. And I need a latlon...
      Help greatly appreciated !
      DB
        The 3D point it returns is in the format 'long/lati/height'.
        The 'X' is the longitude in degrees [actually it's in 'inches'!]
        The 'Y' is the latitude in degrees [actually it's in 'inches'!]
        The 'Z' is the point's height in inches.
        To return the long/lati use
        latlong = model.point_to_latlong(point)
        (55, -1, 0) - this is for the 'ORIGIN' where I live...
        To set it as 'degrees' - for use in other methods you can use...
        long = latlong.x.to_f lati = latlong.y.to_f high = latlong.z.to_l [in current units]
        -1.0, 55.0 and 0.0
        You can then use
        ll = [lati, long]
        Note how perversely it takes 'lati/long' in the reversed order from the 'point' itself!
        my_ll = Geom::LatLong.new(ll)
        LatLong(55.00000N, 1.00000W)
        my_ll.latitude >>> 55.0
        my_ll.longitude >>> -1.0
        It's not the easiest or most logical method in the API!
        πŸ€“
          Didier Bur
          Thanks a million TIG πŸ‘
          DB
