    Writing Ruby Console messages to a text file
    9 Posts 5 Posters 4.3k Views 5 Watching
    • Al HartA Offline
      Al Hart
      Sketchup.exe has a feature where, if you redirect its standard output to a file, then any messages which would be sent to the ruby console are written to the file. However, Sketchup.exe does not flush this file, so if there is a big splat, or if you want to examine the file while Sketchup.exe is running, it will not contain all of the messages.
      I have created a ruby script which overrides the Ruby Console, and write its messages to a file, and flushes each message.
      Place this in the plugins folder, and it should create a file called c:\tmp\ruby_trace.txt which contains all of the messages which are sent to the Ruby Console (whether the Ruby Console is open or not).
      Give it a try, see what happens, and offer any suggestions you may have:
      !trace_console.rb
      # Copyright 2010, Render Plus Systems.
      # Permission to use, copy, modify, and distribute this software for
      # any purpose and without fee is hereby granted, provided that the above
      # copyright notice appear in all copies.
      # THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
      # IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
      # WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
      printf("***** Loading; %s\n", File.basename(__FILE__))
      # create a class to trap comsole output and send
      # it to a file int c;\tmp
      class CL_rps_console < Sketchup;;Console
      attr_accessor ;debug_file
      attr_accessor ;sfile
      	def initialize
      		# create a folder called c;\tmp
      		sdir = "c;\\tmp"
      		if (!FileTest.exists?sdir)
      			 Dir.mkdir(sdir)
      		end#if
      		@sfile = "c;\\tmp\\ruby_trace.txt"
      		@debug_file = File.new(@sfile, "w")
      		@debug_file.write(;;Time.now.to_s  + "\n")
      		@debug_file.write("SketchUp Version; " + Sketchup.version.to_s  + "\n")
      	end#def
      	def write(smess)
      		@debug_file.write(smess)
      		@debug_file.flush
      		super(smess) # call inherited class write function
      	end#def
      end#class
      # redefine standard output to our new class
      $old_stdout = $stdout # in case you want to turn off traces
      $stdout = CL_rps_console.new
      $stderr = $stdout # trap error displays as well
      puts "-----"
      puts "Console messages are going to " + $stdout.sfile
      puts "-----"
      Sample file contents:
      C:\tmp>type ruby_trace.txt
      Fri Sep 24 00:51:28 -0600 2010
      SketchUp Version: 8.0.3117
      Console messages are going to c:\tmp\ruby_trace.txt
      [EDIT: changed name to !trace_console.rb and added $stderr = $stdout]
      [EDIT: Revised script for mkdir error]
      Al Hart
      IRender nXt from Render Plus
        I might have the perfect candidate for testing. I experience crash without bugsplat with a script in some unknown condition.
        • honoluludesktopH Offline
          honoluludesktop
          Wow, very neat!
            Jim
            Thanks, Al - good idea. You could also log $stderr which might catch some thing additional events.
            $stderr = $stdout
            • Al HartA Offline
              Al Hart
              Let me know how it goes.
              You can add:
              printf("FILE; %s LINE; %s\n", File.basename(__FILE__), __LINE__)
              after almost every line in the ruby file to trace down the bug splat.
              (Or if someone knows another good way to trace ruby files, let me know)
              Al
              Al Hart
              • Al HartA Offline
                Al Hart
                I had place an underscore at the front of the ruby file name, (_trace_ruby.rb), so it would run before other ruby files.
                But I was confused. It turns out the _ comes after a-z in sort order, so I changed it to !trace_ruby.rb so it would come first.
                I wanted to make sure that it caught printf's and puts's from other .rb files in plugins, so I created !r.rb with prints "!R" and !u.rb which prints "!U", and sure enough, !R did not trace to the file, but !U did.
                I have updated the script in the original post, and also added the $stderr stuff as suggested by Jim
                Fri Sep 24 09:53:21 -0600 2010
                !U
                Al Hart
                  dburdick
                  I'm trying to redirect $stderr to a file, but it doesn't work. $stdout works just fine but not $stderr. It appears that when Sketchup generates an error message, it does not call $stderr, but outputs to the console through some other mechanism. Anyone have any ideas on this.
                  • Al HartA Offline
                    Al Hart
                    Keep your ese on this thread as well: [Plugin] Trace Ruby messages
                    Al Hart
                      dburdick
                      Hi Al,
                      Thanks - will do.
