    [Plugin] Contour Maker v1.6
    64 Posts 24 Posters 75.2k Views 24 Watching
      JavadQaitouri
      Hey,I installed the file as an extension but it is unsigned, I can't use it, any tips?
        Its status as Unsigned doesn't mean you can't use it. If you have the loading policy set so it loads, it will work just fine.
        Which version of SketchUp are you actually using? Your profile shows 2020 Free/Make but there is no such version.
          JavadQaitouri
          I use 2020 can,t open it when it is unsigned.
            Yes. It can be opened when unsigned if you set the loading policy to Approve Unidentified Extensions or Unrestricted in the Extension Manager.
            This extension works just fine in SketchUp 2020.
            Please update your profile.
            • 4 / 4
