    UI.savepanel & SU6
    2 Posts 2 Posters 290 Views 2 Watching
    • T
      tomasz
      I doubt it will be fixed, so it is just note for the rest of the developers.
      Windows Vista SU6.4.112 PL a command below will not show 'save panel' and will immediately return nil.
      UI.savepanel "Test", "C;\\Test", "test.tmp"
      This one will work:
      UI.savepanel "Test", "C;\\Test\\", "test.tmp"
      The only difference is the path not being closed with backslash in the first example.
      EDIT:
      The method does not accept forward slashes in SU6 (Win). It does in SU7+
      Thomas was faster πŸ˜„
      • thomthomT
        UI.savepanel "Test", "C:/Test/", "test.tmp"
        This also returns nil in SU6.
