    Extend tool
    7 Posts 5 Posters 1.1k Views 5 Watching
      Builder Boy
      I need a tool that will make the selected edges longer by a set distance.
      Untitled (2).skp
      All my plugins
        diegog321
        Hemmm...
        You forgot to say please...
        There might be a lot of plugins that do it, but you (and me) are unaware of.
        • mitcorbM Offline
          mitcorb
          I believe there is a ruby at Ruby Library Depot, or Smustard. Also, possibly Didier Bur's Projections Tool?
          Just use a keyword search. Also, take advantage of the Plugins Index permanent topic I believe in the Plugins subforum.
          • H Offline
            haynesc
            why not just turn on the extensions in styles? ... or do you actually need the lines drawn
              Builder Boy
              I do actually need the lines drawn.
              All my plugins
                You can deal that whit the Smart Push Pull by a4chitect ๐Ÿ˜‰
                It's not automatic for that you want but that can help ๐Ÿ˜‰
                http://forums.sketchucation.com/download/file.php?id=36397&t=1
                Just select after only faces(without segments) (and kill them)
                For this Selection Toys by Thomthom is your friend
                Make only the top and a side then make a two copy mirrors with the 3 corner lines ๐Ÿ˜‰
                Mirror by TIG is also your friend
                  2D Tools - Adjust Tool = extend line(s) by TIG can help too! (multiple selection possible)
                  Just Draw with the Offset tool a rectangle external from a face (with wished size)
                  Then call the plug all extensions are made just by one click + drag โ˜€
