    Help with Rafters
    26 Posts 5 Posters 2.0k Views 5 Watching
      mac1
      @dsafety said:
      Thanks Mac1. Your solution appears to be flat while using Tig's method I ended up with several facits. How did you come up with your rendering?
      My approach is not a rendering and as noted was meant to show you just a rough idea what your roof will look like. What I did was use the ridge and eave beam edges as a ref ( rafters follow that profile) connected at each end with a line one to the other then used the plugin Soap Skin and Bubble to create the surface. This is not acceptable for your final model. Using the first and last rafters could also be tried but have not looked at that. TIG's approach will work but it would take many facets ( maybe as many as 50 etc) for each space between the rafters. The reason is the double curved surface. Fredo's curviloft will do that work automatically and does not look bad. As I have been harping about I think you should reconsider your approach unless you want that type of double curved surface and are willing to spend the bucks. There is a solution which keeps the splayed beams and will result in a flat roof but I stopped working on that approach based on your previous comments about the OP approach was good enough. Attached is where I stopped. You can finish if you want. The concept is the splayed beams are raised in the back bringing their edges in plane with the center. The beams were corrected and made components because of the varying dimensions. A slope reference( 17.589 degs but needs verification) was measured then moved up by 6/cos( 17.589) to account for the rafter plum cut ( should have used 2x4) was made at the front and then copied to the back to establish how much the splayed beam must be raised. From there is it just a matter of laying in the rafters. You can trim the roof line by using a section plane. Note the clipped corner needs correction
      Good Luck
      Bob
      Outdoor Room-5_mac1A.skp
        dsafety
        Thanks again Mac1. I think I understand and agree that having a flat roof would be much easier to build and probably cost a lot less. If I raise the center post furthest from the fireplace, (or lower the hight of the post at the fireplace) to the point where the roof will all be on one plane, it should work out. I do not know how to do the math to figure out how much to raise or lower these posts. Could I use guidelines instead?
        Bob
          mac1
          Bob
          Take a look at the ref triangle I have drawn in the above post. The one point(A) of that at the top outside beam edge is the start of the birds mouth. The other is on the line at the plum cut(B) at the top beam. If you now take and move/copy the triangle down to the far end and set the one point(A) on to the out side beam edge the triangle will cut at the ratio you are looking for to keep the same slope. Opps I noticed I went high in my last post vs low 👿 Since you think this is a possible solution I'll see if I can do some more tomorrow ( PM it will be)
            mac1
            dsafety
            FYI
            Flat roof concept
              mac1
              dsafety
              Final Update
              Trimmed eaves to 12, plum cut at ridge, mirrored roof
                dsafety
                Thanks Mac, I have encorporated your roof into my model. It will be much easier to build. I will post a finished model soon.
                Bob
                • 2 / 2
