    Help Installing Thea Ruby
    4 Posts 3 Posters 379 Views 3 Watching
    • dermotcollD Offline
      dermotcoll
      Hi Guys
      I have downloaded the Thea program and the sketchup plugin. The Thea program is running on my machine and I can see the help files etc. I have also downloaded the sketchup plugin to export SU models to Thea but I cannot get it to show up on my plugins list. It is in the plugins folder and all the components seem to be there but it does not show up anywhere on the SU interface. Is there a problem with SU8 or have I messed up? (which is very likely)
      When you burn your arse - you gotta sit on the blisters!!
        Dermot, is there a box to tick for the plugin under Window>Preferences>Extensions?
          dermotcoll
          Had a look there Dave but didnt see it. JUst checked again and no its not there. I have uninstalled and reinstalled it three times now but no joy as yet.
          • N Offline
            notareal
            It may be some ruby conflicting issue or permission problem. Just speaking from my own experience with SU8 and SU2Thea - for me this combination seems to run better than SU7. Please, continue this in Thea support forums http://www.thearender.com/forum/viewtopic.php?f=82&t=3562&start=10
