    Help with Acad generated Dxf file
    8 Posts 3 Posters 776 Views 3 Watching
    • honoluludesktopH
      honoluludesktop
      Although I utilize Dxf in my work, I do not use AutoCad and the Dxf files that I generate differ according to the application creating them. I need a Dxf generated from AutoCad as follows:
      1. A block consisting of 6 rectangular closed polylines in the form of a 12"x12" cube with a line on the top surface.
      2. A block consisting of a circle 12" in diameter with an arc in it.
      I need to know which version of autocad is used for this export, and would appreciate anyone that can post this file for me.
      • KrisidiousK
        Krisidious
        ok here you go... hope this is what you want... let me know if it works.
        Autocad 2010
        HD 1 & 2
        By: Kristoff Rand
        • KrisidiousK
          Krisidious
          is this what you want? this is Number 1.
          if you could give me a screen shot of what you want I can put it up.
          edit. ok I see it now... give me a minute.
          By: Kristoff Rand
          • honoluludesktopH
            honoluludesktop
            Hi Krisidious, Thanks. I can work with them. Interesting, none of my apps can read the files. Perhaps I require Dxf from an earlier version. Since I can't yet view them, I am assuming that each file contains one block; one the cube, and the other the circle.
            • TIGT
              He can save as an earlier version DXF - e.g. 2000 ?
              • KrisidiousK
                Krisidious
                here they are exported to DXF 2000
                Acad 2000 DXFs
                By: Kristoff Rand
                • honoluludesktopH
                  honoluludesktop
                  Hi Krisidious, The 2000 files opened with all of my apps., but I can use both of them, thanks! Upon visual inspection the Dxf models contain lines, 3d faces, circles, arc, but only a few polylines. I didn't take into account how drawings are made in AutoCad. Perhaps there is no specific tool to create a polyline, and thus the model consist of 3dfaces. Thanks again, these are of help to me.
                  • honoluludesktopH
                    honoluludesktop
                    Well, I spent the day looking at the way various applications read and write dxf files, as well as the differences between Acad versions.
                    My own Cad program outputs a dxf that is no longer compliant with Acad v 11 (maybe not even since 2000). But fortunately, it hasn't affected my work. I have been writing a SU plugin to modify my Cad2Dxf output in order to improve its performance. As long as I was doing this, I thought I might be able to post a DxfIn for SU-free users, but have discovered that there are too many considerations, requiring rewriting my code to accomplish even a very basic version of this. Good thing for me that my Cad2Dxf is easy to understand.
                    Thanks for the support everyone, hopefully I will finish soon:-)
