    Temporary message box
    7 Posts 4 Posters 643 Views 4 Watching
    • Al HartA
      Al Hart
      I would like to load an informative message box, but take it down after a couple of seconds - without haging to wait for the user to click OK.
      I am going to see if I can do this with a timer, killing the timer thread.
      Has anyone done this already?
      Al Hart
      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
      IRender nXt from Render Plus
      • thomthomT
        Should be doable with a webdialog - since you then have methods to open and close those windows.
        • Al HartA
          Al Hart
          Start and stop timer did not work as well as I had hoped:
          def temp_message
          	$bdisp = true
          	$id1 = UI.start_timer(1, false) {
          		puts "A;" + $bdisp.to_s
          		if $bdisp
          			$bdisp = false
          			puts "B;" + $bdisp.to_s
          			UI.messagebox("test3" )
          		end#if
          	$id2 = UI.start_timer(2, false) {
          		puts "STOP"
          		UI.stop_timer($id1)
          end#def
          Al Hart
          • Al HartA
            Al Hart
            Thanks,
            I'll have to try a web dialog, but I will wait a few hours to see if anyone already has one.
            Al Hart
            • Dan RathbunD
              Dan Rathbun
              @al hart said:
              ... but I will wait a few hours to see if anyone already has one.
              Don't bother waiting.. you cannot use a messagebox. They are modal (and Ruby stops until they are closed.)
              Choice is a WebDialog, or if Win32 only, you can use Win32 API calls to create you own non-modal window.
              I'm not here much anymore.
              • Al HartA
                Al Hart
                By "waiting", I meant that maybe someone already had a web dialog which did this and would upload it...
                (I can always hope! 😲 )
                Al Hart
                • P
                  Pout
                  In the webdialog use this code:
                  <body onLoad="setTimeout('self.close()',5000)">
                  with 5000 being the amount of milliseconds that the message is shown
                  Haven't tried but should work
