    Trouble with Greebles
    11 Posts 5 Posters 2.3k Views 5 Watching
    • J
      jhearcht
      SketchUp 6.4.265 on Windows XP
      As a serial novice, apparently I'm missing something that a more experienced modeler would take for granted. No response on the expert Plug-in forum, so maybe it's more of a newbie thing.
      I downloaded Greeble 2, along with Progress Bar and Offset. Put them in the Plug-ins folder. After a re-start, "Chris Fullmer Tools" appears in Plug-ins menu.
      I select a grouped rectangular box with Juniper vegetation texture. I want to add some roughness to the surface. So I select the Greeble tool and enter some numbers. After clicking OK, nothing happens. I also trying selecting just one surface, but no go.
      I was assuming the tool would draw a 2D grid with my +/- dimensions, then pull each piece up to a random height. If I could get some kind of response, I could then play with the numbers to get the look I want : pointy pyramids may do the trick.
      Do I need to draw a grid before selecting the tool? Is there an auto grid tool? Should I greeble one face at a time? What do I need to do before invoking the Greeble tool?
      Thanks for covering my ignorance with your intelligence.
      PS---Please pardon the old Star Trek reference to Tribbles. πŸ˜„
        A simple rectangle (reverse the face else volumes of Greebles will be inversed)
        Gride by Protrude (apply several times)
        Volumes by Grebles one time
        [attachment=1:2xyht60k]<!-- ia1 -->protrude_greebble.jpg<!-- ia1 -->[/attachment:2xyht60k]
        and then apply Random Painter by Chris Fullmer πŸ˜‰
        [attachment=0:2xyht60k]<!-- ia0 -->random.jpg<!-- ia0 -->[/attachment:2xyht60k]
          Can you put an image ?
          or just a little schema of what you do want πŸ˜„
          Is there an auto grid tool? yes but not in Greeble 2 πŸ˜„
          Should I greeble one face at a time? no hoppfully πŸ˜„
          use the Protrude plug (who is a cousin of Greeble 2) by Jim Foltz πŸ˜‰
          You can make the gride in Protrude and go back to Greeble 2
          or make all in Protrude
          The 2 plugs are crazzy progs 😎
          • J
            jhearcht
            Pilou
            Thanks for the help, but I still can't make the scripts do what I want to do.
            Which is to make this :
            http://home.mindspring.com/~gnomon/Box.jpg
            Look like this :
            http://home.mindspring.com/~gnomon/juniper.jpeg
            I couldn't find anything like this on 3D warehouse, so I'm trying to make a simple, low-poly shrub. I don't need a realistic image, just a suggestion of a Juniper planting. Step by step instructions would be useful, if you have the time. Thanks. πŸ˜•
            • Chris FullmerC
              That is not exactly the scope of the plugin. It takes and does a puhpull on a face. Or multiple faces at the same time. You might be able to get it to do something that looks sort of like that, but you would have to start with a shape sdifferent than a box. You would need an organic shaped mesh that already in the appoximate shape of your bush. Then you could greeble the faces a little, and scale down the extrusions so they come to nearly a point. That might make it come out all spikey looking. But in general, what your wanting to do, is not what this script does.
              Chris
              All my Plugins I've written
              • W
                wyatt
                A request for something similar to this was asked for at 3DBC this year....kind of an "organic greeble" if you will. I actually tried creating this last night with subdivide and smooth, greeble, and protude, as Chris described. And while I came up with some cool geometry, it was nothing that resembled the bush you want. Do you have to use a 3d shrub or would a 2d face-me work?
                • J
                  jhearcht
                  Chris
                  Thanks Chris
                  The Googled Juniper photo is not exactly what I have in mind in form, but close in texture. This is a continuous low linear border about 12" to 16" tall, and the shape is more rectilinear than bushy. A 2-D face-me prop won't do, because the camera will be looking down at the edging. I used a highly modified version of a small low lumpy shrub by Darrell Smith in another location, but this one needs to have a little more surface variation.
                  I can modify the place-holder boxes to make them somewhat more organic. But I need to keep the polys down, so a mesh would be overkill. All I want is to add some irregular texturing to the boxes. I was hoping the Greebles would do triangular or pyramidal shapes instead of rectangles.
                  Does SketchUp do "Bump Maps" or "Embossing"? I didn't find any reference to that technique, but it may be known by another name. Greebles are more like "3D displacement mapping".
                  I appreciate the suggestions, but I'll keep looking for a way to extrude a long low bushy shrub without overburdening my 6 year old CPU with too many things to think about. It tends to smoke when rendering 3D. 😞
                    I believe not Sketchup itself but numerous of "SU Plugins' rendering" if you don't want an external renderer πŸ˜‰
                    • EscapeArtistE
                      EscapeArtist
                      I think you broke it just to use the title "Trouble with Greebles"! πŸ˜†
                      • J
                        jhearcht
                        Pilou
                        Thanks for the link. I'll keep that in mind for future projects. For now, I gave up on the greedy Greebles, and just modified a 3D Warehouse shrub. It has an organic shape, but no surface texture. From a distance though it looks good enough.
                        Escape
                        Would you believe : Tribulations with Tribbles?
                        • Chris FullmerC
                          You might have better luck with something like the fur plugin. It might take some playing around, but you might be able to get a good result.
