Layout Model Styles
SketchUp 6.4.265; Layout 1.4.268 beta; Windows XP
After sending an SU model to Layout, I made some minor position and material changes, but not to the in-model Style, and then re-sent the file. Before those changes the Layout (1pt profile edges only) style matched the model. After the changes, the Layout style seems to have reverted to the default, with 3pt Edges and Profiles. Those line weights are too heavy for the small size of the image in the Layout.
I'd appreciate any suggestions to force Layout to match the model style. The selected Style name is correct, but the edges and profiles are visually wrong. I have open/closed, and re-sent, and updated several times. Any ideas?
After making the changes in the style in SU, make sure to update the style (there is a round arrow in the style dialog). Also, best is to use scenes for a LO export where the scenes are updated (after you update the style), too.
Register LoginAdvertisement
